Drain hole??
toybox06
Oklahoma
2022 Bronco, 2015 Mustang
Has anyone else seen this light shining through? Wondering if it is a drain for the upper switches. I can block the light in the center on the right side center of the switches.
Ford Bronco Drain hole?? IMG_5029
CV428
2023 Bronco OBX, 1969 Mustang Mach 1 428CJ
I'm no Lightologist, but I think that comes from the sun :)
(and no, I haven't seen it there in mine)
Bugkillah
Keith
North Augusta, SC
Base Sas, Badlands, Wrangler, Nissan Frontier
Picture from where you can block light…
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
It's the predator using his laser pointer to pester you.
That's very interesting. I'm curious where the hole is. No water intrusion?
Moontraveler1984
McCordsville, Indiana
2022 Wildtrak - for Bradford
Do you have something hanging from the rear view mirror that is causing light to be reflected?
toybox06
toybox06
Oklahoma
No it’s a small hole on top of the dash on the right side between the rubber switches and plastic nearly center on the right hand side. I’ve only seen it 2 times it looked like a small spotlight. And I started searching to block reflections until I found it.
toybox06
toybox06
Oklahoma
This was just now in the pitch black of my garage using my wife’s phone light.
Ford Bronco Drain hole?? IMG_5031
Ford Bronco Drain hole?? IMG_5032
