Door Window Recalibrate?
Chris Tyacke
Hampton roads VA.
Jeep liberty
Does anybody know how to recalibrate a door window? When fully closed, the driver side door window is about 1/4" low compared to the passenger door window. The gap causes air to whistle in the cab when I'm driving.
My service department is 3 weeks out for their guy to recalibrate...
* Note the black thing in front of the glass is my key fob so my phone camera would focus on the edge.
Driver side door window with 1/4" gap below molding.
Passenger window tucks up under the molding.
It's like one leg is shorter than the other, you'll need a chiropractor to fix this one.
Milkbaby
Keith
Lake Charles, La
2019 Ram 3500
Roll the window down and hold the button down for 5 additional seconds. Roll it back up and hold the button in the up position for 5 additional seconds. This should reset the window to factory.
I did mine this morning, I read the two sec rule down hold then up hold repeat twice. I’m back to working correctly.
bpurtz
bpurtz
Bryce
Oregon
JKU Rubi, Sierra Denali, Taco TRD Pro, 4Run LTD
The problem I'm experiencing is more complicated than resetting the "Bounce Back Override". Your windows are already aligned and your two sec rule...repeat process simply reboots the window up/down controls so your windows operate correctly.
The glass on my driver door is out of alignment and has to be manually adjusted which requires a pretty involved door panel removal and more...
If anybody is experiencing a whistling sound inside the cab, it's possible that one of the door windows is out of alignment - it's easy to see the problem if you compare the fully closed positions of each window - you can try to DIY with the steps outlined in the "Shop Manual" attached in post #14 by @Ksjrb03 or you might ask your dealer to fix it...
I'm going to the dealer...
Ksjrb03
Tx
F250
Ya I keep contemplating doing it myself. Haven’t decided. Hate the dealer.
bpurtz
bpurtz
Bryce
Oregon
The service department at my dealer has corrected the window problem I experienced - the service tech indicated that the fix is a 40 step process that takes several hours.
UtahG2022
Amanda
Nothing Yet
If hotdogthud’s method doesn’t work go into your manual and look up bounce back override. Give that a shot as well.
It's not in the manual. I checked. Says how to override it.
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Try turning to page 103 or your manual, entitled, 'Overriding Window Bounce-Back".
