Door Sill Warning Label Overlays...?
MNBigfoot
MN
What is "Streamline shipping protection tier 1 $1.99" that appears in my cart? Just an added fee? Is there a way to remove it, as it appears that it is an item I selected in my cart, which I did not.
StickerFab
Fort Myers
www.stickerfab.com
2021 Bronco Badlands / 2023 Bronco Raptor
With this we put a different insurance on the order which has a better claims process.
Can be removed if you go to the cart first before checkout.
StickerFab
Fort Myers
www.stickerfab.com
That's a good call... I think one for the bottom 2 , and one for the top single would work. The spacing on my bottom two seems a little bit different than the pic.
That would be the issue. If the spacing varies too much, we may not get enough coverage in some vehicles.
Would be nice if everyone could measure and chime in. Both height and width in case they are not stacked on evenly.
Thanks
MNBigfoot
MN
Thank you, figured it out now.
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
It looks like a 3" wide 8" long strip would cover the bottom and a 3"X 3" for the top. Ignore the bottom sticker, that is where I place my oil change reminder sticker instead of the windshield.
Ford Bronco Door Sill Warning Label Overlays...? IMG_3689
MFP2241
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Mine are a little farther apart...
Ford Bronco Door Sill Warning Label Overlays...? 20230206_201113
jughead
jug
sunshine
jeep
What is the barcode with fastpass for?
jughead
jug
sunshine
jeep
Thanks. On mine that says fastpass.
Is your alignment about the same? Would be better to make a single strip vs a patchy mess of covers IMO.
What is that FastPass for? I found the same barcode sticker on mine, but don't know what it's for.
