Door Hinge Wall Mount on Etsy
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
Saw this wall mount posted on Etsy. Hopefully this is first of many to come. Not sure which route I want to go yet. I would assume more options to choose from should be hitting the market soon.
21+ Ford Bronco Door Wall Mount
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Surprised there wasn't something like this already. Wonder if you have to buy 2 if you have a 4-door. Makes it fairly pricey...
AceGoliath
AceGoliath
Charles
IL
It does look like you would need to buy 2 for the 4 door.
I have door bags and haven’t quite pulled the trigger yet as I have been out of town, but I have been looking at these. I figured I can hang the door bag handles on those hooks but I would need to verify the bag handles are big enough to fit onto the ledges. Also not quite sure about the bags themselves. They may lead to scratching if sand or dirt makes its way in the bag.
Lumenix Heavy Duty Door Hanger Bracket, Wall-Mounted Removable Window Channel Door Holder Storage Rack Compatible with 1956-2021 Jeep Wrangler CJ YJ TJ JK JKU JL JLU LJ JT (4 Pack) https://www.amazon.com/dp/B08GLQ5Y5D/ref=cm_sw_r_cp_api_i_YBT9JSFNMY9VNKXMTMEY?_encoding=UTF8&psc=1
Ford Bronco Door Hinge Wall Mount on Etsy 626A6248-B3A5-42B2-873A-41A702211B98
mikec426
Russellville, AR
I don't have the bags. I'm thinking I'll probably make one of those roll-around racks with PVC pipe someone posted recently.
mikec426
Russellville, AR
Those hangers for Jeep doors might work. Be sure to check the stitching on the bag handles to see if it's robust enough to carry the weight of the door.
AceGoliath
AceGoliath
Charles
IL
I thought about having a couple resting/back-up hooks on the bottom of each door.
ZipZit
Zip
Las Vegas NV
2020 Escape, 2008 Mazda3
Isn't the Etsy posting very similar to the device I proposed back in September, 2021?
I'd share the specific details and dimensions, but I don't have any Bronco doors to play with. Sigh. Still waiting..
My original drawing... obviously for four doors mounted to a single stud under drywall.
Ford Bronco Door Hinge Wall Mount on Etsy _bronco-door-holder-png
Stuffed
Rick
United States
$200 lol no thanks. I feel I have a good idea... Just gotta wait for the bronco to show up....
kodiakisland
Arkansas
Looks like a great product, but $200 seems steep.
JaxGtc
That hinge hanger is going to be carrying some serious weight. I don't think I would be using drywall anchors for that one. :D
What keeps the opposite end of the door form opening away from the wall? Or worse, both opening and banging into each other?
Bababue
Tom
Pa
2014 Ford F-250 lariat
My exact thoughts.
DrewBronc21
New York
2020 Subaru STi, 2024 M2
Seems like a lot just to hang a couple of doors. I’m thinking just a modified wheeled dolly on the floor.
Chippewa-Pin
Western PA
Santa Fe, Tucson, Z4, 69 Chevelle SS
Pretty expensive. A few soft hooks on a Rubbermaid wall slot screwed into the studs... all for around $50.
