Let me preface this by saying I emailed Dobinsons USA and was told that they will release their IMS Shocks and Struts along with a diff drop kit in the next 2-3 months. The IMS is height adjustable along with being compatible with the many different Dobinsons springs.
One of my biggest questions was regarding their current spring offering C19-566 which is rated for 0-110lbs on the front of a 2.7 4 door Bronco. I expressed my concerns that it is an inadequate payload as my bumper, winch, and skids would be close to 300lbs. I was assured that my payload should be fine and would still get 2.5-3" of lift. Interestingly enough they offer springs rated for 300lbs for the 5th gen 4runner. I ran that setup on my 5th gen. This is a direct quote from Dobinsons, "Dobinsons can design a stronger spring if needed but we haven't seen the need for it as of now, the IMS are adjustable and you raise the seat if you need to lift more. We didn't want to raise to much the spring rate as the ride frequency number goes out of our desired range."
Apparently the C19-566 springs are also compatible with the stock yellow bilstein springs. For those of you looking for heavier springs.
Dobinsons makes good stuff, I'll attach links to the pages I was looking at.
https://www.dobinsonsdirect.com/products/dobinsons-ims-lift-kit-ford-bronco-2021-on
