- Alan
- Jun 16, 2020
- 42
- 530
- 555
- Sacramento
- Toyota Tacoma
- Badlands
Whats wrong about the 2.3?Get the 2.7 so there won't be any regrets down the road.
Buyer remorse down the roadWhats wrong about the 2.3?
If it's a budget thing, do the 2.3. BUT, if you ever plan to sell your Bronco, do the smart thing and get the 2.7... it will be the better choice overall, because you will get: *immediate gratification, better/smoother power, *the 2.7 injection will run cleaner, and *there will probably only be a penalty of +/- 1mpg.Will the 2.3 be able to turn those 35’s or will it be a slug?
How is the 2.3 buyers remorse?Buyer remorse down the road
How will the 2.3 be overworked with 35 inch tires? Its the same engine found on the ranger.The 2.3 is going to be overworked in this rig . Just get the 2.7 and enjoy what the Bronco has to offer
The Bronco is pushing close to 5,000 pounds that’s a lot of weight for that 2.3 to lug around . The stress and strain on that motor is not worth the savings up from IMOHow will the 2.3 be overworked with 35 inch tires? Its the same engine found on the ranger.
my volvo xc60 is about 4000lbs with a 2.0 turbo pushing 250hp. it's not sluggish and doesn't get over worked. even with a full car. the bronco is estimated at 4500lbs max (don't know where you are getting 5000lbs from). with a slightly larger wheels you'll see a difference but it's not a drag racer. if you want something fast with power, get a mustang.The Bronco is pushing close to 5,000 pounds that’s a lot of weight for that 2.3 to lug around . The stress and strain on that motor is not worth the savings up from IMO
Overstressing and wearing out motors is not really a thing today. Motors wore out in the old days due to inferior rings, cylinders, bearing materials, and subpar oils compared to today. The 2.3 will push 35's for several hundreds of thousands of miles. Poor maintenance will be the main reason people will have premature problems.The Bronco is pushing close to 5,000 pounds that’s a lot of weight for that 2.3 to lug around . The stress and strain on that motor is not worth the savings up from IMO
2.3 overworked? The the 3.6 In the Jeep is dying then. All the 2.3 needs to take it to the level of the 2.7 is literally just the simple 93 Octane tune. It will give you the same power of the 2.7 for less money.The 2.3 is going to be overworked in this rig . Just get the 2.7 and enjoy what the Bronco has to offer
You might want to research what early generation V8s made for power. A lot of those engines are rebuilt and still running today. Plenty of them made waaay less power then the 2.3 and didn't have the capability to tune for more power. You got what you got with them and a lot if them where placed in vehicle's that weighed even more then the Bronco.The Bronco is pushing close to 5,000 pounds that’s a lot of weight for that 2.3 to lug around . The stress and strain on that motor is not worth the savings up from IMO
