Diode Dynamics Reverse Kit | Now With C1R (Brake Function)
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hey guys. We're happy to announce that we just received our NEW harnesses in yesterday and our Diode Dynamics Bumper Mounted reverse kits have been UPDATED.
They now feature an OPTIONAL red-backlight (running light) with the option to have a brake light function as well (on the C1R).
For the past few years our Diode Dynamics reverse kits (the bumper mounted kits) were only reverse. No back-lighting. The ktis were developed around our existing Baja Designs kits (which don't have any backlight options). BUT due to popular demand we've finally updated them. We have new pigtails that we're including with the kits that are plug and play and support the running/brake function.
We're also giving you, the customer, the option to choose the backlight or not on the SS3 (which can save you money if you don't care about the running light feature).
As an added bonus, if you opt for the C1R kit you'll get the added BRAKE function. This makes the red running light to BRIGHTER when you step on the brake.
Agian this is for our kits that install UNDER the bumper. A lot of customers prefer this look along with the installation as it's VERY easy to install it and doesn't require a lot of wires to be ran, since we use a plug and play in-line pigtail for the factory tail light.
You can check out the kits here: https://www.4x4truckleds.com/2021-f...w-diode-dynamics-lights-kr-off-road-brackets/
Also, another unique feature of our Reverse kit is we also give you the option to turn your reverse lights on from an upfitter switch. This is great if you are doing an off-road event and need chase lights. Just snap on some yellow covers and you've got chase lights. We also have built in protection so that when you turn on the lights from the upfitter your factory reverse circuit is NOT being back-fed power. This helps protect the circuit and avoid confusion to other drivers on the trail.
Ford Bronco Diode Dynamics Reverse Kit | Now With C1R (Brake Function) 1706979843634
If you prefer the spare tire mounted option, we're also offering this kit with the C1R as well: https://www.4x4truckleds.com/diode-dynamics-stage-series-reverse-light-kit-for-2021-ford-bronco/
dvogel
Mountain View, CA
Forester XT
Are there links to any install videos or instructions? I am particularly interested in how these lights tap into the existing factory tail lights.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We provide installation instructions with the kit.
We made an in-line pigtail. It connects in-line to the factory taillight harness. Just unplug your existing tail lights from inside (easy to get to). Plug in our harness. Plug the taillight harness back in and now you can connect the lights to it. Pretty straight forward
Ford Bronco Diode Dynamics Reverse Kit | Now With C1R (Brake Function) 1707102226307
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
So for those of us with the spare tire kit and no brake light what are our options?
Well, this kit we're talking about here. It goes under the bumper
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
psdtime
Tom
CA
2026 Bronco
Has anyone tried to use these lights for a towed vehicle set-up? I mean use the red back lit as a running light, hook the "brake" feature to the blinker circuit from the tow vehicle harness and leave the back-up function tied to the Bronco's revers lights. So, when the Bronco is being towed, these lights handle the braking, blinking and running light functions. When the Bronco is off leash and driving normally, these lights only function as a back-up light. It seems like this could be done without having to deal with a harness with diodes in them that could cause issues with the factory lighting.
