Different GOAT programming based on the model and package?
BRDDOGN
Paul
Virginia Beach, VA
2018 F-150 Platinum and BMW X3M40i
Hey everyone. I apologize upfront if this has been asked and answered (I could not find anything) and if this is posted in the wrong spot. However, I could use some insight.
Me and my buddy when off roading this weekend. I have a Badlands w/ Sasquatch and he has a Badlands w/out without Sasquatch. His does have an aftermarket 3-inch lift and new 35’s. The weird thing was that we experienced 2 completely different setups when using the Mud/Rut GOAT mode. My Bronco went it into 4H and locked the rear diff. His Bronco did the same; however, his added a feature. It detached the stabilizer bar. Mine did not. Also, his ABS went hyperactive the entire time on any downslope. Mine never made a peep.
My question is: are the GOAT modes programmed differently based on the model and package? Thanks everyone!!!
Here a few pics of the great day!
Edited: My friend is an experienced wheeler. Hi JK crawler is a manual.
Ford Bronco Different GOAT programming based on the model and package? 2F2B3D92-F2AA-4AB5-8107-35942EA17636
Ford Bronco Different GOAT programming based on the model and package? BA480D7E-D735-4395-97FC-F7C5EF56116B
BigBend530
Dominic
Oroville, CA
2022 Ford Bronco 2Dr.
Were you both going roughly the same speed when shifting into Mud/Rut Mode? I believe there is a speed limiter for when it does/doesn’t disconnect swaybar.
Combustion_King
Derek
MA
Yes
Were you both going roughly the same speed when shifting into Rock Crawl Mode? I believe there is a speed limiter for when it does/doesn’t disconnect swaybar.
he said mud and ruts mode, not crawl.
id have to go turn mine on see, ive never used mud/ruts, but i do know rock crawl, puts mine in 4L, sway off, rears locked.
BigBend530
Dominic
Oroville, CA
Thanks. Edited my previous post. Mud/Rut mode does not automatically disconnect swaybar. I dont have that feature so indont know if you can manually disconnect it in that mode.
Ford Bronco Different GOAT programming based on the model and package? Screenshot_20230212_175054
rtaylor
R
ID
19Raptor, 22Bronco
There shouldn't be a difference. Swaybar disconnect is allowed in mud mode (allowed in any 4H/4L mode at low speed), it's just not the default. ABS could be a problem with erratic footwork or not using low gear on low traction downhill (not maintaining control).
Combustion_King
Derek
MA
Yes
You can disconnect the sway bar in normal if you want. I use normal, and put my 4 wheel drive stuff on manually vs using the G.O.A.T. modes.
BRDDOGN
BRDDOGN
Paul
Virginia Beach, VA
Good morning and thank you for the response. We were both stopped when we placed the Broncos into Mud/Rut.
Good morning and thanks for the response. Agreed. We experienced the same when we used that GOAT mode.
BRDDOGN
BRDDOGN
Paul
Virginia Beach, VA
Good morning and thanks for the response. My friend is an experienced wheeler but I will pass that along. He is used to his JK crawler that is a manual.
BRDDOGN
BRDDOGN
Paul
Virginia Beach, VA
Your second table is interesting. Ours did not lock the front in mud/ruts. And if I recall correctly, I could not lock the front in 4H regardless of mode. I’ll need to double check that.
orion
Jeremy
17' F-250, 17' Explorer
Correct, front locker available in 4L only...
