Device Holder - 67Design vs BulletPoint Mounting ?
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
been looking for a reasonably priced option to hold my cell phone that doesn't bounce around a lot - was liking the look of the 67D magmount g3, but holy cow that's pricey, and their Black Friday "deal" is laughable - BPM ended up doing 20% off their entire line for Black Friday, and while they don't have a magnetic solution I like as much, the clamping phone holder looks like a solid solution, and their prices aren't as ridiculous as 67D. Any other options to consider?
JDoc92
Tim
Northern Illinois
2017 Honda Ridgeline
Tackform. Recently came out with new device rail.
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? BE086393-3EB9-4B1C-AAC7-141B8A3D9EC3
Garemlin
Delaware
I have Bulletpoint. Rock solid. My phone doesn't move at all. They are supposed to be releasing a Bronco specific mount soon. Right now I just use their 1/4-20 20mm ball attached to the dash mounting point.
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? 26A1B44A-3FE3-4B13-9AEB-4D11F72A0AE2
da_jokker
Jeep Wrangler JKUR
Ironically I was just wondering if there was something like this. I don't need a whole "system". Just want something to hold my sell phone. I was going to see if I could simply adapt my rugged ridge older in my Jeep to the Bronco....but I really like your setup.
Do you have a link for what you got? I glanced at their site and didn't know if I needed to Frankenstein a bunch of replacement parts, or that whole piece comes together.
Garemlin
Delaware
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
If you’re after the most rock solid of setups, you’ll want our billet SLAP BULLETPROOF MOUNT and a single billet BALLS moint point, found here.
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? C58FC7A3-24D3-49A4-966C-5FAF4B8E0B61
You eighty-six the flimsy plastic panel with the threaded feature that will eventually fail you and you incorporate a solid 1” or 20mm mount ball for your socket arm. A 1/4-20 316 Stainless bolt mounts the BALLS to the SLAP. THE SLAP is bolted to your dash. 💪🏽 You exchange one flimsy OEM mount point for three ultra rugged mount points.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
I have one and I’m pretty happy with it.
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? 7B51AD3B-F3C8-489A-BB1D-C0FB8C9C93B0
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? F47FBFDF-5818-4BE8-B034-9DFDC0198262
StoicAF
Kyle
texas
2022 Bronco
what do you attach or how do you use that ball thing.
JHawk
Ray
Heartland, USA
Fusion Sport
Post #2, 5, & 10 demonstrate how the arm attaches to the ball. On the other end of the arm is where the device mount goes. The Archetype SLAP replaces a plastic factory piece
JHawk
Ray
Heartland, USA
Fusion Sport
I have several items from Eightlug that I will finally get to install later this month. I cannot wait!
BASE729
Joe
Boston
I just mounted the 67 Designs full rail. The 1/4-20 mounting hole has terrible flex front to back. So no matter how tightly you torque the screw, it has crazy wobble. Is this an issue with my 1/4-20 threaded hole? I can flex my phone a good 1/4" up and 1/4" down based on the flex of the dash.
Winds of Change
Chicagoland
2022 Bronco Obx SaS/2021 Bronco sport Badlands
Tackform is the way to go. And at the moment the switch panel is 3m double sided tape
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? 20231008_084007
Ford Bronco Device Holder - 67Design vs BulletPoint Mounting ? 20231008_084011
