Dash Cam Placement?
Tigerwalk
Rory
Fredericton
2021 Bronco Wildtrak
Hey all, just got an Mai70 Dash Cam Pro Plus +
I really don't off road now that I'm disabled, can't handle the ride.
This camera is for road use only.
Would you mount it to the slot on the dash (or is that too low visibility wise)?
Or, would you mount it by the rear view mirror?
Thanks
Ground_zero298
Scs michigan
I have a mirror dash cam and find the video to better at that height. On the dash itself could block some plates and such at close range.
Tigerwalk
Tigerwalk
Rory
Fredericton
With the mirror mount, do you use the auxiliary switch?
Ground_zero298
Scs michigan
Mine was 12v and I tapped the back or the rear view mirror harness.
