Michigan Curt LED towing module 4/7pin ready $65.00
emore93x
Doc
2021 Outer Banks
This is a curt lighting module for Bronco's with LED rear tail lights.
It is 4 and 7 pin ready.
You will need to:
Connect to the battery (length of wire is already attached).
Connect the reverse lights (wire marked on harness).
Connect to brake controller (wire marked on harness).
I purchased this from etrailer in January and decided to use the Ford brake controller and module setup so I no longer need this.
Was removed in March.
Ford Bronco Curt LED towing module 4/7pin ready $65.00 PXL_20240614_201919912
Ford Bronco Curt LED towing module 4/7pin ready $65.00 PXL_20240614_201909725
GSkipper
Rich
Jeep WJ
I’m interested. Local pick-up?
emore93x
Doc
2021 Outer Banks
Where are you at?
I am in the Auburn Hills area.
I would need to grab it from upnorth this weekend but could meet you next week or Sunday after 5:00pm
