- Josh
- Apr 25, 2022
- 379
- 536
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Curt 13493 Fits 2021-2022 Ford Bronco Class 3 Trailer Hitch w/ 2" Receiver in stock at TMB!
2021-2022 Bronco CURT Class 3 Trailer Hitch with 2" Receiver Features: Rated to 3,500 lbs. gross trailer weight and 350 lbs. tongue weight Compatible with weight distribution hitch (4,000 lbs. WD / 400 lbs. WDTW) Protected by a durable high-gloss black powder coat finish Co-cured in a rust-resistant liquid A-coat, inside and out Equipped with an open-back receiver for easy cleaning Made in USA (may include imported hardware) Trailer hitch weight ratings are limited to vehicle manufacturer's stated capacities Includes installation hardware Does Not Fit Ford Bronco Sport The 2021 Bronco CURT Class 3 Trailer Hitch with 2" Receiver is has the Strength to Pull 3,500 LB The 2021-2022 Bronco CURT Class 3 Trailer Hitch with 2" Receiver is specifically engineered with a custom fit for the 2021-2022 Ford Bronco allowing for easy integration with the vehicle's existing features and offers a reliable connection to your trailer. This custom fit allows for the most the efficient and secure functionality while maximizing the total towing capacity to a massive 3,500 LB. They are designed to accommodate a wide variety of towing applications. It works perfect for towing fishing boats trailers, popup campers, ATV trailers, utility trailers, cargo carriers, bike racks and much more. Every CURT custom hitch is thoroughly tested at the in-house testing facility and is adhered to the SAE J684 testing protocols to make ensure dependability of this product. No matter what your outdoor passions are, you can expect a reliable product for your towing needs.
Be confident in your towing ability with coverage of a limited lifetime warranty and plan your next adventure. Expert Crafted for Maximum Strength and Made in the USA The 2021-2022 Bronco CURT Class 3 Trailer Hitch with 2" Receiver is stringently tested in accordance with SAE J684 to ensure a weight carrying capacity of 3,500 LB gross trailer weight and 350 LB tongue weight. It is compatible with a weight distribution hitch to provide more stable towing and a weight distribution rating of 4,000 LB WD and 400 LB WDTW. It also features a 2" receiver tube opening to accept ball mount or other hitch accessory with a 2" x 2" shank. All CURT custom-fit receiver hitches are made in the USA to ensure quality from design to finish. They are engineered for a precise fit to your 2021-2022 Ford Bronco and are welded using a combination of manual and robotic operations for speed and accuracy. For product longevity, each hitch is dipped in a liquid A-coat for rust prevention, inside and out, and then co-cured in a durable black powder coat finish for a maximum rust, chip, and UV resistance. Product Specs: Receiver Tube Size: 2" Shipping Weight: 15 LB HUB_USA: D01 Weight Carrying Capacity (WC): 3,500 LB Weight Distribution Tongue Weight: 400 LB Tongue Weight: 350 LB Product Weight: 14 LB Weight Distribution: 4,000 LB Material: Carbon Steel Finish: Gloss Black Powder Coat Warranty: Limited Lifetime Warranty (1-year Finish, 1-year Parts) Fitment: 2021-2022 2-Door Ford Bronco 2021-2022 4-Door Ford Bronco Does Not Fit Ford Bronco Sport
Fitment: 2021-2022 Ford Bronco
