Cousin Eddie's Build Journal
Cousin Eddie
Jack
Pennsylvania
Cadillac
I figured I'd start a thread to document my build. I'll edit this post as Items are added or removed. I'll add a couple of posts below for thought on other components. Feel free to post comments or suggestions...
Starting point 07/09/2021:
2021 Ford Bronco Badlands, Sasquatch, 4-door, 10sp auto, 2.7 V6, Lux, Tow Package
07/21/2021:
Wouxun KG-1000G GMRS radio, Nagoya NL-770G Antenna
9/21/2021:
Front and Rear Husky X-Act Contour Floor Liners
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Drive Train
<Reserved>
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Interior
<Reserved>
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Recovery
<Reserved>
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
General
<Reserved>
j_marinelli
Spring Branch, TX.
@Cousin Eddie any feedback you can share on the Husky liners? How is fit and finish with the rubberized floor in the badlands?
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
They fit very well! I was a little concerned the "spikes" on the back might damage the floor but I've been checking it daily for signs of indentation but nothing so far.
Ford Bronco Cousin Eddie's Build Journal 1634167292766
Ford Bronco Cousin Eddie's Build Journal 1634167446509
Ford Bronco Cousin Eddie's Build Journal 1634167513241
Ford Bronco Cousin Eddie's Build Journal 1634167555929
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Wouxun KG-1000G GMRS radio installed above the driver's side visor...
Ford Bronco Cousin Eddie's Build Journal 1634167756560
Ford Bronco Cousin Eddie's Build Journal 1634167798052
j_marinelli
Spring Branch, TX.
Thank you for the feedback!
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
Lighting
Probably the next item I buy will be lighting. Been looking at the Baja Designs XL-80 for the A-Pilars:
https://www.bajadesigns.com/products/Ford-Bronco-21-On-A-Pillar-Kits.asp
Finally got the Baja Designs XL-80s and installed them. Originally ordered directly from Baja Designs but they had an 8-10 week lead time. I saw Northridge 4x4 had them in stock and roughly $100 cheaper. In addition, I signed up for their newsletter and got an additional $50 off.
The only negative I have to say is if you are using the upfitter switches and harness kit, you need to use either Aux 1 or Aux 2 as the lights draw ~10.2 Amps. I might rewire it to use the provided relay so I can control it via Aux switches 3-6.
Ford Bronco Cousin Eddie's Build Journal 1636789218125
Ford Bronco Cousin Eddie's Build Journal 1636789433997
Cousin Eddie
Cousin Eddie
Jack
Pennsylvania
Cadillac
As you can see in the pictures above, also installed the Aeroskin II Deflector Trail Armor.
