Compressor for the Budget Conscious
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I was looking for a compressor for my father for the holidays and got a notification of 30% off at NAPA Auto Parts. Brought this dually down to $85!
Maxi Trac
Figured some of you would appreciate the deal!
EDIT: duh, the code: SAVE30 - 11/26 ONLY!
redone17
redone17
Cold Spring, NY
Whoops! Forgot to post the code. Ha.
After 11/26 you can use code NAPATEXT for $20 off.
redone17
redone17
Cold Spring, NY
I own this compressor and it’s legit. It’s faster than the ARB dual.
Damn! That’s impressive.
Question for you. I found it strange that the outlet off the unit is male instead of it being a quick connect female. Meaning you need a hose with two female connections if you want to use an upgraded inflator. What was your solution?
redone17
redone17
Cold Spring, NY
I ended up replacing all of the hardware with Milton fittings and got a high quality hose and inflator for my dad. Still under $150.
Very odd to me that the hose end off the compressor is male and why there is 18” of hose before that male fitting. Instead of the traditional female quick release mounted to the unit itself.
Ford Bronco Compressor for the Budget Conscious 759B611F-2A06-4574-B890-0E01CEAD7623
mcinfantry
Lee
Louisiana
Badlands 2 door
Any space under the hood to mount it?
