Changing amber grill lights?
Wedge
North Georgia
2018 F150 FX4/ 2013 Mustang GT/ 2016 Mazda CX-9
I’m not sure if this is even doable. But, does anyone know if they make a white LED replacement bulb for the amber LED grill lights? I’ve googled it with no luck. If so, is it possible to turn them into DRL’s?
5GENIDN
Joe
Idaho
I am assuming you must have a Raptor.... Those three amber lights in the grill are required by code because the Raptor is so wide.... Not kidding....
Wedge
North Georgia
No, I have a base model. I’m asking about the amber indicators next to the headlights
5GENIDN
Joe
Idaho
My apologies... I misunderstood. Interesting because mine are white from the factory. I believe that there are some people using forscan to change the color from white to amber. The only amber from the factory I knew of was the Raptor (other than the three marker lights). There may well be other models that come amber that I do not know about or if your vehicle is used then someone may have changed them using forscan or they may have purchased aftermarket.??????
Wedge
North Georgia
No problem. For the signature lights, they are clear LED. Non-signature, they are amber and used as indicators. I bought it new, so it should be the same across the board…but I could be wrong.
I plan on getting forscan, I wasn’t aware you could change the LED color. I was wondering if a clear LED is made for it and can it be turned into a DRL, similar to the Bronco sport.
5GENIDN
Joe
Idaho
Well I learned something new today. I am also disappointed in myself for not having paid closer attention. So yea... there are a couple of threads that I have read where people were trying to mimic the raptor (at least that was my take) they were discussing using forscan to do it. a 2 vs a 1 on one of the ladder lines.
Sorry but I am not going to be very helpful here.....
