Ceramic - System X?
Agswin
Ardi
College Station
2024 Bronco Raptor
Anybody heard of this product or used it?
Bschurr
NY
Yes - have it on several vehicles & it’s great stuff. I do get annual touch ups/re-coat.
I had my Raptor coated with the 5 year System X and a year later when I had stealth PPF applied, they needed to remove the ceramic coating and the shop owner told me that it was one of the most durable ceramic coatings that he has ever removed. I had an alternative product applied over the PPF and it’s good but, the System X was better.
Agswin
Agswin
Ardi
College Station
2024 Bronco Raptor
Thank you, I have done more research, and it appears to be top notch. Ceramic Pro is very finicky to install with a bunch of rules for weeks after install and is mostly great marketing. My guy is quoting $1400 including windows and my painted top. Read nothing but great reviews and I like that it is Carfax registered
Bschurr
NY
Thank you, I have done more research, and it appears to be top notch. Ceramic Pro is very finicky to install with a bunch of rules for weeks after install and is mostly great marketing. My guy is quoting $1400 including windows and my painted top. Read nothing but great reviews and I like that it is Carfax certified
Don’t forget to ceramic coat the rims too!
NC_Oak
2024 4 door 2.3 sasq
never used it - but I sware by GTechniq. Pretty easy to apply, lasts a long time, and doesnt wear off easily either.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
Do yall go off-roading in your Broncos? Does it protect against brush scratches? In Texas they’re called Texas pinstripes. Drives me crazy. Would love to find something other than a garage that would protect my “Lone Ranger”
tonytexchappy
Tony
Texas South Plains
08 Mini Cabrio, 22 Maverick
Some coatings/installers overblow the scratch resistance of their products. Yes, it will — slightly. It’s a few microns but it’s there.
Bschurr
NY
Yessir, I wheel my rig. Ceramic coating is primarily for cleanliness - PPF is for protection.
For your TX use case, I would suggest PPF - anything else will only provide minimal protection from the most minor branches/brush/rocks etc.
Agswin
Agswin
Ardi
College Station
2024 Bronco Raptor
What he said👆
Just keep in mind, there are different applications of Ceramic. What he and I are talking about - System X, that is applied by a certified installer and has warranties and can be Carfax registered. So when you go to sell your rig, it actually shows on the Carfax that you have Cermaic applied not "oh yea I did it" with no proof but a piece of paper from the guy that did it. I am not looking to wax on ceramic myself.
NC_Oak
PPf is the way to go but pretty costly unless you do it yourself. I havent done the bronco, I plan to tho. A lot of relatively straight body panels and removabilityy will make it pretty easy
Agswin
Agswin
Ardi
College Station
2024 Bronco Raptor
PPF and Ceramic have different roles. Most people on high end cars will do both. PPF and then ceramic over it. You get paint protection for easy cleaning/swirls etc and impact protection from rock chips/branches
Ceramic is more about mud/dust than scratches.
You need body armor, PPF or MEK Magnet panels for pinstripes.
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I call them desert pin stripes. I asked the people that did my PPF and ceramic coating if the ceramic coating would protect from pinstriping. They told me It probably would not. I told them I like to keep the sides waxed well so at least make them slippery and help to keep the brush from digging in as much. They said ceramic would also function in that way but I would probably still get the pin stripes.
cubes32
Nevada
4Runner, Audi S4
I have had System X on my Bronco for three years. It was Diamond SS on the paint, and Revive on the hardtop, fender flairs, bumpers, all the exterior plastic. It is very good product line. I'm touching it up annually with System X Renew spray, which can be bought retail or on Amazon, and you can do the whole vehicle in under an hour. The initial application of the Diamond and Revive took many hours, as you only want to work on a small section at a time, and you have to get the timing of wiping after the flash just right.
