Central Jersey lift shop
New Jersey
Hello bronco peeps,
I’m looking for a reputable shop for a lift in the central New Jersey area.
Any recommendations appreciated.
Thank you!!
That_Red_Bronco
New Jersey
OKAuto (OK4wd) whichever name it is now. They are up in Stewartsville. https://ok4wd.com/
Been using them since the 80's. Never had a lift installed, but done tires and alignments. @Merc4x4 has them install a lift a few months back though.
Thanks for the input! Will check them out.
Merc4x4
steve
NJ
Great guys. I’m always happy with their work. I had them put on a full Icon setup. They marked all the bolts which makes it easy to check them. Maybe all good shops do that?
They also did the goose gear plate and tailgate table for me.
On the Mercedes they put on spring spacers and tires, but they usually don’t install customer parts. I had to pull some strings for that.
I’ve also used them for regular maintenance/repairs on my sister’s xterra. Zero complaints, great work, if a little expensive. But worth it knowing it’ll be done right and make sure it’s road worthy.
