California Carli double-shear steering
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Brand new Carli double-shear tie rod system. Still in the original box. MSRP is $1395, asking $1000.
Ford Bronco Carli double-shear steering IMG_1515
Ford Bronco Carli double-shear steering IMG_1514
From Carli website:
– Greasable and Rebuildable Inner Tie-Rod End
– Billet Double-Shear Knuckle Bracket for Outer Tie rod end
– Billet Outer Tie-Rod housing 3/4″ Teflon-Lined FK Heim
– Heat-Treated 4140 Moly Coated Tie-Rod
Less than HALF the toe-change of the factory tie-rod through the extended travel range
Fitment: 2021+ Ford Bronco 4×4
**NOTE: This DOES NOT fit Ford Bronco Raptor**
Ford Bronco Carli double-shear steering CS-BRS-21
Ford Bronco Carli double-shear steering CS-BRS-21.8
https://www.carlisuspension.com/pro...nts-ford-bronco/21-23-bronco-steering-system/
