Can someone explain the Ford reservation page?
Akinmx
Memphis, TN
2006 Ford F150, 2011 Ford Fusion
Hi all! I originally put my $100 deposit down on a Big Bend (July 15) reservation. Like everyone else I changed my mind a million times but finally settled on a Wildtrak.
On 02/22 my dealer put an order in for my Wildtrak. I received a confirmation email from Ford on my order the next day. I am #110 in line with my dealer whose final allocations are exactly 100 broncos but I'm hopeful I'll make the cut due to others in front of me wanting items held for MY22.
My question is... when I log in to Ford's website and check my reservation this is what it shows:
Ford Bronco Can someone explain the Ford reservation page? Screenshot_20210416-034158_Chrom
Is this right? Is this what everyone else gets after they ordered? Shouldn't it at least say Wildtrak by now? Just curious. Thanks.
Erock
US
2018 F150 Alpine edition
I don’t think it updates with the changes you make, trim wise. So I’m assuming your original reservation was of a Big Bend. I made a door count change that showed up, but the original color and all stayed the same. Hope this helps.
LalasBronco
Laura
Triangle, NC
69 Bronco (past), 74 Super Beetle, Ram, 70 MG
I originally reserved an Outer Banks but actually ordered a Badlands. Mine is updated to say Badlands.
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
It should change if you switched trims. Mine did at least. I originally ordered a First Edition (well, the dealership did) but had it changed to Badlands. My order page on Ford’s website changed from First Edition to Badlands once this happened.
You should be okay though due to receiving an email from Ford confirming your Wildtrak order.
Erock
US
I feel like I’m the absolute last person on Fords priority list... I almost get nothing from them about anything... nor anything really updated. 🥺
Tonka1
Brad
Green Bay, Wisconsin
Jeep Wrangler Willys
I would be more concerned about the order sheet than what the website says.
DeltaBravo
Delta
MIKES MOM
Apparently the DORA sheet is right.
LSU Jonno
Huntsville, AL
2022 Bronco
I reserved an Outer Banks then ordered a Badlands. My page has been updated to show a Badlands.
Rlack75
Ron
Marietta GA
I had the same issue.
I called the bronco support line, aka the change dealer number.
Verified my reservation, sales code and order code were all tied together.
They were!!
(Still no email - 7/13 10:13pm res 3/1 order)
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
It's nothing to worry about.
Well documented on the forum of people's Ford profiles not updating after an order is placed. Additionally, there's a way you can check the code on that page and *maybe* see your actual order... but even then, plenty of documented cases of it not being correct either.
Look up your order details through the Ford.com website code.
The gold standard for what order was placed is the Order Summary sheet your dealer can provide you. It lists absolutely everything that's included in the order as well as some other info that you may or may not find useful.
Ford Bronco Can someone explain the Ford reservation page? Order Summary Screen Shot Redacted
