build week 10/24
Classic28
Brandon
Maryland
Nissan Titan
What's your build consist of? Mine is in my signature. I'm trying to make some correlation between the builds. I know, no logic is employed by Ford when it comes to builds.
Badlands, 4dr, sas, mic, mgv, lux, 2.3 manual, cactus grey
SaMcRo89
Josh
Savannah, GA
Silverado
Sup guys! Just got bumped to y’all’s week. This is my 5th bump. I’m beyond frustrated. Began with week of 9/26 then 10/10 then 10/3 then back to 10/10 and now 10/24. I believe y’all’s week is the last of the MY22 being built so this should be my last bump.. unless they bump me back up.
Badlands 2 door, 2.3, manual, high package, eruption green
Jjt24
JJ
Toledo Ohio
Escape, Mustang
isnt that the end of the 2022 run ?
It's gotta be close, I'm currently an 11/02 build day.
Nah, I'm a my22 with a build day of 11/02. You still have another week to go back but I hope you get bumped up!
SaMcRo89
Josh
Savannah, GA
Silverado
Damn that’s not promising. Hopefully I get moved up but if not at least I have a vin.. I was hoping to take delivery before Thanksgiving but now who knows when I’ll get it.
wiingnut
Southern Michigan
'08 F-350 , '19 Mustang GT , '22 Bronco 4-Door
I haven’t received an email regarding a scheduling date, but I have been keeping an eye on it at work. Currently, I’m scheduled 10/24. Personally, I expect the build date to be modified at least 3 more times before the Bronco is actually built 🤣, since it’s already changed 5 times since 9/1. On the bright side, I have a MY22 VIN. I’ll eventually get my Bronco. Best of luck to everyone.
Not long after I posted this, I was switched to 10/26. Then on Wednesday, I was told that MAP was sent home early due to no wire harnesses. With all the constraint issues, it wouldn’t surprise me at all to have a Nov build date. Our plant encounters downtime on a weekly basis due commodity problems. Keep the faith Bronco peeps, we’re almost there
Classic28
Brandon
Maryland
Nissan Titan
Welcome, I started off in the 10/10 then got bumped here with a 10/28 build day. Hoping it stays and get delivery before Xmas.
Rockledge
Darryl
Fayetteville N.C.
2022 Race Red Sasquatch , 1951 Willy's M-38
Hello: I just got bumped here from the 10/10/22 group.
Per my Dealer print out - these are my build dates:
Sept 26th-Oct -3rd-6th-10th-15th-16th-14th-24th-28th.
70Bronco
Jimmy
Charleston, WV
70 Bronco; 11 Jetta TDI; 03 Duramax
I checked the back door tracker a few weeks ago and discovered my 2022 Badlands was scheduled for build week 10/24. Then, I was bumped to build week 10/31. I just checked the back door tracker and now, I've been bumped to build week 11/7. It's still showing as a 2022 model. So, recommend others check the back door tracker because I didn't receive an email from Ford indicating the bump to 11/7.
Ford Bronco build week 10/24 november-production-date-jpg
Mudhorn
Charles
Vermont
2022 Ford Bronco Badlands
Pushed back a week. Halloween Bronco!!
Ford Bronco build week 10/24 785BDB00-6B7F-48DB-8219-BA95E0739409
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
That it was @Classic28, it was set to be built on the 25th. Now the week of the 31st…. Who knows?
When did you get the push email from Ford? My brain is telling me to survive another Tuesday without an email and I should be good.
YULQQKN4
Stephen
New York
2022 F150 502A BAP, 2022 MUSTANG GT 6 SPEED COUPE
Just got moved from 10/27 build day to 10/24 build day....first time anything ive ordered recently has gone in that direction. Not holding my breath though.
HeyDobby
Debbie
2024 F250
I was also moved to the 24th from the 27th…when do we see window stickers?
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
The trend has been 7 to 9 days prior to blend date - approximately.
