Bronco VIN
Clarence
Clarence
Boerne, TX
MKZ
Found this ad for 2021 Bronco at Mabank Ford 903 887 2121 .....the explanation I was given was the vin was assigned to someone with a reservation, seems a bit early.
Ford Bronco Bronco VIN 1603306677803
ColoradoGuy
Picture does not match description at all.
jayhawkco
Aurora, CO
2006 Nissan Xterra Off Road
Looked up the VIN. That is indeed a VIN for a 2021 Bronco Sport Outer Banks with a 1.5L I4 made in Hermosillo, Mexico.
Bauer
IL
Chevy
Are they trying to sell his reservation from under his nose? Hey, you gotta pay ADM, since I've already got interest in your reservation.. haha
Outer Banks starts at $32,160...$36,140 fully loaded (minus accessories) (n):mad:
Spooled
Republic of Texas
Raptor, Model 3
Jp215
James
Pennsylvania
2015 F150
Really? I just ran the vin through oasis and got a message saying pre-production vin not yet produced
XCR440
Nathan
Union, Iowa
21 Badlands traded for 22 Badlands, to 23 Wildtrak, to 24 Wildtrak
Vin starts with 3 means Mexico, so Bronco Sport. Bronco being US made will likely start with 1 (could be 4 or 5, but Ford is usually 1)
It did make me jump on the vehicle locator and I do see a lot of Bronco Sports listed on there today (as in production/Plant status). These should be the first ones built (I think job 1 is the 26th) For those that keep thinking things will be built in batches, this proves otherwise. I see all the models, base, outer banks, Big bend and Badlands in all different colors just like we normally see production go. Interestingly out of the 25 listed on the first page, only 3 have the 4 cyl, the other 22 ore 3 cyl. Hopefully Ford plans for the opposite mix on 2.7/2.3.
Deleted member 3063
Guest
When you order is assigned a vin it means the build is scheduled. The last time I had a vin assigned to my order it took 4 weeks to deliver.
XCR440
Nathan
Union, Iowa
Thats the way it used to be, now it seems to be more jumbled up and they seem to be dropping in vins at different points. For example on Bronco Sport
My first one (vin 03923) is currently scheduled for Dec 14th. Second one (vin 06243) is Nov 23. The last one I got in the second month of allocation (vin 10557) is scheduled for Nov 17th. Fist one is a 2.0L, so they must be short, last one was a Big Bend so the low end ones must be getting pulled ahead.
I'm looking for similar to happen on Bronco where instead of weekly Ford does a monthly (or even quarterly) scheduling pull, which will mix up the orders more, but make sure that the ones that can be built get built. This means that a dealer might have 2 schedule same day, yet build be 4 weeks apart (if Ford does monthly scheduling) based on commodities. Nothing consumer or dealer can do, just wanted to point it out so if it happens to you, its not your dealer screwing you or anything, just the way the system works sometimes, if demand is higher than supply on options.
