Diabolical Inc
Diabolical Inc
Lux Sponsor (Level 2)
shop.diabolicalinc.com
2020 Rubicon, 2021 Bronco Wildtrak
Just looked as I wanted one for the new bronco but 1399 is a lot more than it was before. Guess I can wait for a sale to happen.
Our best deal of the year is happening right now with the bundle deals. Metal and shipping prices have gone up exponentially, considering all 28 parts and pieces are cut, bent and powder coated locally in the US.
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
5* out of 5* . Purchased and installed. Quality is very good (+10 points). Build, instructions and video get a meh (0 points). I am not a fan of the pins at all (-5 points), I understand why but I just don't like them or how they "line up". There are shared parts with Jeep models which is clever(+10 points). The downside is many parts in the end appear to be an afterthought (-10 points). Oh we can use the same part as the Jeep but we have multiple gaps that need filled, let's make some small parts and plug the holes/openings that way. It's unfortunate the level of Ikea this security enclosure is (-1,000 points) all pieces not labeled (only bolts/nuts/washers were labeled). The support and communication is unlike anything (+1,000 points). Phone calls were answered, text messages were responded to. You will not receive support like this anywhere else and for that alone it is 5 of 5 stars. Solid, good looking, functional but pain in the ass to build and install. Leave yourself an afternoon or entire morning to build. Watch the entire install video 80+ minutes before attempting to build. Packaging is also a masterclass in how to protect your investment. a major carrier that rhymes with Ed Fex managed to punch a too big for me whole in the side of the box. But it was double boxed (Ninja!) everything was safe and sound. Then I built it and said many bad words that hopefully my neighbors didn't hear.
tl;dr I am a happy customer but wow I don't want to build one again any time soon. I'll help anyone local to Seattle/Tacoma area but give me a couple weeks to recover.
Diabolical Inc
Diabolical Inc
That review is well something…..
Yes we share parts with the Jeep. This is for your benefit, not ours. If we didn’t share parts and order in bulk metal, this system would be over $2,000 retail.
Not sure why you don’t like our videos, it’s every bolt, nut and washer. Could you imagine if we skipped sections or fast paced it? Written instructions would be 30 pages.
The complexity of the system is what makes it the best on the market with the features and modularity it has. We take pride in everything we do, nothing is an afterthought.
Extra pieces that fill in gaps? I can only assume you mean the tailskin corner fillers, blame Ford for the crappy soft top design on that one.
Gator007
Kevin
Modesto California
4 door Bronco
I went to go purchase one for my 2023 4dr Badlands and had a bit of sticker shock. Finally took delivery after a 2 year wait and unfortunately with inflation the price of the slipstream went up considerably. I either have to wait for a 20%-25% off sale or just settle for the Ford one which I really don’t care for at all. Sad part is I have 260,000 point and could get the Ford one for free. 🤯 Decision Desision.
Diabolical Inc
Diabolical Inc
We have replaced more of those Ford/Tuffy Chinese boxes then I care to say.
The likelihood of seeing a 25% discount would be impossible, we wouldn’t be in business. The likelihood of another price increase is eminent. US aluminum is going up again.
Gator007
Kevin
Modesto California
4 door Bronco
That’s what I figured. Looks like I will go without for awhile. 🥲
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
Any Memorial day sales?
Diabolical Inc
Diabolical Inc
unoffically yes we are putting one together but forums members have a standing 10% off with code
forums10
which will likely be the same as the Memorial Day sale.
JetG
Jet
TX & FL
forums10
Okay didn’t know it if was going to be like last years 20% off. I knew 25% wasn’t going to fly but thought it would be the same as last year.
Diabolical Inc
Diabolical Inc
Unfortunately profit margins have been drastically reduced. We would have to raise the price 10% to give a 20% discount. We don’t really want to do that!
sundaeman
Joel
MD
I'd be interested in updated rear soft top latches. The OEM ones are pretty flimsy. I attached strap pulls so I could pull the rear down and find I have to pull kind of hard to get both sides latched. I do have the IAG struts installed.
If you're having trouble with the rear skin rubber trim pulling off, you can remove the rubber grommet that's at the top center of the tailgate. I found it was the culprit for pulling the trim off on mine.
Also, I'd love ideas on how to stop the pins from rattling so much, while still leaving them functional. I took some of the hard foam from the packaging and cut it down and shoved it in between the pin hooks and the enclosure to keep the tight, which helps a lot, but not great looking.
I know it's been a while, but what did you use for strap pull downs on the rear?
jtrh0ne
James
Syracuse, NY
2023 Bronco Raptor
Hey all - sorry for thread necro, but wondering if anyone installed a slipstream with the Ford slideout tailgate? Seems like it might work - the floor bracket seems like it might mount under the tailgate bracket @ forward most D-ring hole?
Ford Bronco Bronco Slipstream Security Enclosure 1722904525615-ch
However not sure about the lower lip on the lower wall panel.
Ford Bronco Bronco Slipstream Security Enclosure 1722904346469-n
Seems like that lip may bump into the tailgate mount frame.
Ford Bronco Bronco Slipstream Security Enclosure 1722904651802-26
Anyone try this? I'm not opposed to some trimming, but may not want to rip that entire lip off as it might be a bit structural?
CKXVII
CK
F-150
@jtrh0ne I’ve outfitted my Bronco with this set-up. Installing the brackets gets a bit tight — I used the SOTG bolts w/ the SS brackets to anchor both to the Bronco.
The only modification you’ll need to make is cutting off about an inch of the SOTG sub-floor (the end facing the backseat) so that the top portion fits. I can’t remember the exact measurement, but it’s just enough to expose the internal cardboard structure.
Once you have your measurement, use an X-ACTO knife to cut along the seam where the rubberized flooring meets the carpeted liner. Try to keep the carpet liner intact so you can use it to help seal the edge later. I cut along the seam until it reached the D-ring on both sides, so I had a nice parallel line to fold the liner under. I used some Saran Wrap and painters tape to keep the liner folded down and out of my way.
I ended up using a cut-off tool on a guide rail & a pull saw to make my cut. Once I cut through the rubberized part, the pull saw did a good job finishing the cut.
I probably overdid this next part, but last thing you want is an exposed edge causing v1 hardtop issues in your cargo area 😂
Apply Flexi-Seal Rubber Spray (black) & let dry (can use hairdryer to help). Apply another coat and while wet, Trim and apply Flexi-Seal Tape (black) along the edge. Once that’s dry, use super-weld on the taped edge and wrap the carpet liner over the edge. Trim the excess and use some light heat to blend the edge.
I had some rips in my liner and not enough material at the end so I opted to use some excess spray & heat with the carpet liner. It’s been about a year and still holding up fine.
Ford Bronco Bronco Slipstream Security Enclosure FEE9B147-E065-4FAB-92C4-0B0894B391DD
Ford Bronco Bronco Slipstream Security Enclosure IMG_1726
Ford Bronco Bronco Slipstream Security Enclosure IMG_1724
Ford Bronco Bronco Slipstream Security Enclosure IMG_1725
Ford Bronco Bronco Slipstream Security Enclosure IMG_1730
jtrh0ne
James
Syracuse, NY
2023 Bronco Raptor
Awesome, I'm pulling the trigger. Thank you @CKXVII for such a detailed response, very much appreciated!
