- First Name
- Andrew
- Joined
- Mar 7, 2020
- Threads
- 16
- Messages
- 4,888
- Reaction score
- 8,425
- Location
- North Carolina
- Vehicle(s)
- 2021 Ford Bronco
- Your Bronco Model
- Badlands
Mine came in a few days ago but I have to wait for it to stop raining
Where did you find the video for the soft top? I only seen the hard top one.Definitely watch the install video and if you have the soft top watch the separate, much shorter install video.
I was blown away at the package for the slipstream. In the day and age of “ throw it in a box” Diabolical Inc went above and beyond with this.
Quality product through and through. Very impressed.
hard top and soft top videos are the same install with only one difference in the skin bracket.Where did you find the video for the soft top? I only seen the hard top one.
Thanks, I received today and will be installing tomorrow.hard top and soft top videos are the same install with only one difference in the skin bracket.
@CKXVII i finished up the install today. Had pretty much the same issue, I could close one side, but not the other. So to remedy this, I removed the Ford latch brackets from both sides and then using a dremel tool, cut away the “raise“ part of the brackets After cutting away both and reinstalling, the soft top will latch easier.@Badbrad do you have a soft top? Did the release handles clear the tail end of the slipstream? I have the IAG EZ lift, which pushes the soft top higher than the prop rod…yet when trying to close the slipstream with the soft top open, it will not clear the release handles…
Glad to see this worked, I broke my passenger spring latch trying to close the top last night. To be fair the spring is only held onto the latch by a tiny piece of plastic. Will make this mod tonight@CKXVII i finished up the install today. Had pretty much the same issue, I could close one side, but not the other. So to remedy this, I removed the Ford latch brackets from both sides and then using a dremel tool, cut away the “raise“ part of the brackets After cutting away both and reinstalling, the soft top will latch easier.
Great write up and pics. I finally got mine from Fed Ex today. Probably get started on installation tonight.Hey guys, pardon the delay as mentioned before... I just picked up my puppy on Saturday and it's been a hell of a few days. I finally finished my write up of the system which can be found here.
https://www.bronco6g.com/forum/thre...rity-enclosure-review-and-installation.42305/
Overall very satisfied with it so far. Let me know if you have any questions or would like any additional photos.
If you have any installation issues you can reach out to me for help if needed. Diabolical’s customer service has been great but I realize not everyone can be around their phone 24/7.Great write up and pics. I finally got mine from Fed Ex today. Probably get started on installation tonight.
Only the slightest. Tbh though I haven’t tried to remedy that though. The sound could be coming from my molle set up on the tailgate too. This weekend I’m going to have my significant other take a drive while I sit in the back and determine what exactly is making the noise. If it is the pins I’m sure can just put a rubber liner in the hole or around the pin like people have been doing with their MIC topsBut do the pins rattle?
