Administrator
Administrator
Staff member
Doug
Bronco6g.com
We just caught the upcoming Ford Bronco Raptor ("Warthog") undergoing testing on the streets of Michigan!
The Bronco Raptor prototype shows off its higher ground clearance, wider wheel arches, and a wider, more aggressive stance. The significant amount of thick camouflage covers up the majority of the vehicle, but the camo can only do so much to disguise what are clearly wider flares.
The prototype rides on a set of BF Goodrich AT All Terrain T/A tires, though we can't quite make out the size (it appears to be a 17inch rim). Out back, a single-exit, dual-tip exhaust is located on the driver’s side.
It's not clear what suspension upgrades are in place, but the Bronco Raptor is definitely expected to feature a more rugged and more capable chassis, even compared to the range-topping Wildtrak Bronco model.
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_001-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_002-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_003-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_004-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_005-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_006-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_007-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_008-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_009-Wartho
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_010-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_011-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_012-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_013-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_015-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_016-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_017-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_018-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_019-Warthog
Ford Bronco Bronco Raptor / Warthog Prototype Spied Testing in Michigan! 2022-Ford-Bronco_Raptor_020-Wartho
Monster79
E
Alabama
15'Stang, 07'F150, 23',96',93',79'Bronco
OOOOooooo I like, minus the flares..
www86aws
Aws
2021 ZR2
Looks like it's wider
Monster79
E
Alabama
Someone come up with tire size using the pavement cracks as reference please...
Its really easy, just find the square root of pineapple pizza
FJ 432
Randy
Littleton Colorado
2003 Tundra
I spy dual exhaust and what appears to be beefier shocks.
Bronco VI
17 F150 Raptor/21 Bronco FE/22 Bronco Raptor
Those are 315/70/17 BFG’s on the Warthog. Same as the stock size Raptor tires. Looks like plenty of room to go bigger, too. I’m ready to trade my First Edition in on it NOW. ?
broncoj11
Everglades
Trunks
Ford Bronco Everglades
Everglades
2023 release or one of the fun things they’re working on?
