- First Name
- Jason
- Joined
- Jan 20, 2021
- Threads
- 7
- Messages
- 1,462
- Reaction score
- 3,047
- Location
- The Woodlands, tx
- Vehicle(s)
- 1986 Bronco XLT
- Your Bronco Model
- Outer Banks
Still have any of these missed out in August?
Gotcha. I figured the Ford way was to remove it and use it on whatever door you were working on, I just didn't know if there made sense to remove them or just leave them if you have one for each door.Can you put them in to put the doors on. Then put the other bolts in and then spin them out and put the lower bolts in. Ford only gives you one having for makes it easy so you don’t need to switch it from door to door as you put them all on
at about 5mins you see the door pins used. Ford gives you 1. With 4 you can put them all in and hang all the doors then bolt all the doors. Also gives you extra if you miss place the 1 you have.Look nice. Got a video of how these are used? Haven't taken off the doors yet.
