jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
I have a non sas BL on order because I get M210s/lockers/Disco/2.7 without spending extra for the rest thats getting replaced anyways. I am going to up it to support 37s with standard 4.46 gearing, I have enough experience with the A10 and 3 OD gears and its close ratio, I am not worried about stuffing 5.13s in, I dont really plan on doing vertical rock crawls. The 4.46 will work and even if it didnt work, the pct of usage in that case for me anyways is not an issue. Its all in planning.
Ditto! Exact same here. BL for axles/lockers/disco/2.7 as well/MGV. I have zero intention of re-gearing. But I'm torn between 35x11.5 or 37x.11.5 All revolves around what can be done to get 37x11.5 to really fully fit without diff drop or total coilover replacement etc. Lots to learn from others before mine arrives tho.
lakesinai
Charleston SC
vrtical
Doug
GSMNP, TN
Fords
Honestly I think this was answered/address specially for BL non sasquatch for sure going to a 37 that it would need a different upper control arm. Even if you ran a new higher coil over setting, it would potentially be an issue if you were do do any real off-roading. This came out of a bunch of discussions on use of spacers as the shocks / design are different between the two options.
pandapaul
Paul
Tallahassee, FL
2021 Badlands Sasquatch
Something looks off. Are those 18” wheels?
I feel the similarly. I don't like it, but I don't know why. Maybe 18" wheels making the tires not look like 37".
dweskamp
Dan
Missouri
2016 GMC truck
Erik said on IG that it was a 2.75-2.9 lift on top of the 1.1 stock Sasquatch lift
So it's a spacer lift with no upper arm change with geometry. Need to see parts. Looks like another non off road kit. FUN HAVER did it right. If you want 37 to wheel off road.
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
So, they paid $2500 for gearing and wider fenders (I would also say badges but they deleted them) assuming that it is an auto and not manual or else they just paid all that money for wider fenders. Sure, you can sell the Squatch suspension components, but you can do the same with the BL too. Doesn't make much financial sense to me to buy Squatch if planning to go 37's with different wheels. YMMV.
@HardenUp can you reach out and ask them if it is auto or manual? Inquiring minds want to know.
For the record, I have a manual BL with all the parts necessary (not named here out of respect for the original content) to lift and go to 37's. Well, except the 37's as my tire of choice is apparently out of stock until later this year.
There will be much more demand for the SAS suspension components as opposed to the Badlands. Especially since the SAS comes with the Bilstein shocks. Again coming from the jeep world, you'd be surprised how many people would pay good money for Rubicon stock suspension components to throw on their sports to get 1/2" of "lift" and marginally better shocks.
You'd probably get $300-400 for SAS suspension. Then take the SAS wheels and tires, you can probably get $1500+ for those. Now now you're essentially out $500 for fenders and 4.7 gearing, and again, a regear is going to cost $1500+. If 37's+ is your goal, it makes financial sense to go SAS to get a bit taller of a gear imo.
I've driven several jeeps with gearing that's slightly out of the "ideal" range for the tire size that's on them. Is it undrivable? No, far from it. But driving one with correct gearing is a much better all around experience.
dweskamp
Dan
Missouri
2016 GMC truck
18s you loose sidewall. Nitto has a 38 now in 17s in the Ridge grapplers.
vrtical
Doug
GSMNP, TN
Fords
A couple of notes on this. Jeep doesnt have a 10 spd auto, Jeep doesnt have twin turbos for low end on demand torque. Also if you go the 2.3/MT route you get the crawl gear anyways.
HardenUp
Shane
Fort Mill, SC
First Edition 2021 Bronco
They definitely specialize in creating badass show type vehicles (not necessarily full blown off-roading), and I don’t think they would argue with that. However, I think this kit does have upper control arms. They are a fun follow on social media.
Ford Bronco Bronco Badlands Sasquatch on 37’s + Maxlider Brothers 4” lift kit BB9AD10C-C04D-45A2-B4D3-29580CDCB191
HardenUp
Shane
Fort Mill, SC
This one is Sasquatch-ed, so auto
Dogstyle
Marc
Ontario
2016 F150 Sport 4x4
Nice
Who supplied the stripe and what are the rims!
Blk Diamond Cheese/2D/2.7/SASQ/MIC/MID/TOW
Tangent27
Tim
Indiana
2013 VW Passat 2013 Road King 1987 BMW e30
Me likey 😍
