Sold: California Bronco 2021-2025 Storage Bag Kit
ScLeCo
Springfield
Charger Hellcat
$280 SHIPPED
VM2DZ78676A00B Bronco 2021-2025, Storage Bag Kit
RagnarKon just made a great video about them
Make the most out of your Bronco's cargo area with a Bronco Storage Kit for maximizing space, organizing gear, and protecting items during off-road adventures.
Take control of your Bronco's cargo space with our storage bag kit. This revolutionary storage solution is designed for off-road enthusiasts. This triangular design transforms your Bronco's rear cargo area, offering secure storage, easy access, and ultimate organization for all your gear.
Kit Includes:
  • R/H & L/H semi-rigid bags with MOLLE panels for added storage options
  • Recommended storage weight limit of 12 pounds
  • Laser cut aluminum mounts allow for fast and easy detachment
  • Aluminum mounts secure easily to sports bar with two bolts
  • Retention pin helps ensure your Storage Bags stay mounted even over the bumpiest terrain
  • When needed, simply remove Storage Bags in seconds
  • Only install Gama Bags with OEM hard top or OEM soft top. Remove bags from mounts prior to fully retracting OEM soft top
  • Not for use with Bronco Raptor Models
  • Not for use with Painted or Body Color Hard Tops
  • ONLY for use with Carbonized Gray, Molded-in-Color (MIC) Hard Tops
    Ford Bronco Bronco 2021-2025 Storage Bag Kit IMG_1285
