Brake Slam
WatchYourSix
NY
2020 Explorer ST, 2021 Bronco, 2022 Maverick
I had the opportunity to be in a Wiltrak 2 door during a full on panic stop. There is an immense amount of brake dive, not quite making the rear unstable, but not far from it. Panic braking at 60 pulling a trailer of any mass would be terrifying. Honestly, if I were to change anything it may be looking into the anti-dive geometry, though that's a massive can of worms.
The only reason the fronts didn't lock is because the antilock system engaged. So, from my experience there is ample braking in this vehicle. Though I'm with you on the pads and lines, because durability, braided lines are much tougher.
Would a leveling kit to reduce rake help at all with the diving when hard braking?
KatieB75
Katie
Escape
I drove a dealer demo 2door and man she dives when you brake hard. Haha I was quite shocked. She also bucks up when you accelerate quickly.
NC_Pinz
Central NC
Welcome to hard braking with a tall-ish softly sprung off road rig with tires with a tall sidewall. I've dealt with this for years. Thankfully we have a decent suspension that allows for some measure of control. I've had some that were down right scary under panic braking.
Bronco1971
Bob
Lots
No, brake dive is a function of the side view of the front control arm mounting points, kingpin, the CG and the wheelbase, among other factors. Hard springs and shock valving can slow the effect, but the geometry is baked in. Suspension design is always a compromise, in this case they accepted brake dive in order to gain wheel travel and camber control.
Like I said, plan ahead while driving and be conservative on pavement.
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Hate those systems- why I got a base- no nannies. I was in traffic on my Jeep car in front of me broke and I had room but the car behind me was coming hard and I wanted to leave him room. Wham hard breaking as the radar picked up the car in front I almost collected the guy behind. Thanks for automatic brake check. Ill pass.
Sorry to burst your bubble, but the base model still comes with your favorite nanny. Yup, it has automatic emergency braking. Activated on my base once, it brakes hard.
Bronco1971
Bob
Lots
FWIW, rake exists in these and many other vehicles for a good reason. While traveling at speed the rake exposes flat surfaces to the front view, meaning that it can create down force to counteract the engine bay positive pressure air packing. Leveling kits are for looks.
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
Good to know 🙏 for sharing that
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Anybody had a slamming on the brakes experience yet? If so, tell about it here.
My experience: 2 door WT, Interstate, 70 mph. Car in front of me suddenly decides to slow down quickly. I did not slam on brakes fully but aggressively slowed down. Felt a little squirrelly and had the feeling of moving side to side a little. It definitely reminds you that you are driving an off road vehicle. Otherwise, it stopped just fine.
do you have a 2.7?
Bronco1971
Bob
Lots
Yeah is have some doubts that pads and lines will improve stopping distances, but I have yet to do a panic stop to see what happens.
My ASSUMPTION is that you should be able to engage abs at any speed.
Pads can reduce braking distances, but as I noted above, there are always compromises. Pads can grab harder due to formulation, but they tend to sacrifice themselves and the rotors faster in the process
It helps to understand what the brakes do, which is conversion of kinetic energy to heat energy. By using a system that can create more friction, it will generate more heat and decrease the kinetic energy faster.
Keep in mind, a lot of theses pads require more heat to work much at all. Those may not work so well off roads.
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Folks that have the 2.3 have vacuum assisted brakes vs the electronic found in the 2.7. Documented better stop distances for the 2.7. Just another advantage that many never consider.
Southern Girl
1974 Bronco/2024 Wildtrak
I drive mostly in the country with deer jumping out, old ladies pulling out in front of you when you're going pretty fast (within posted speed, obvs), people who slam on brakes to turn with no signal, etc. It's like driving the gauntlet some days. I haven't had an issue with stopping quickly. If you are switching to a Bronco from a car, it might feel different, but I drive trucks. I think it stops faster than my truck.
