Borne Off-Road Direct-Fit Bronco Lighting
Status
Not open for further replies.
Mishimoto
Garnet Valley, PA
F-250
Hey folks! Hope everybody has had a good week. Before we roll into the long weekend, I wanted to jump in and share a detailed line-up of our complete lighting offerings for the 2021+ Ford Bronco.
50" and 40" Light Bars
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting Bronco_Light_Blog001
Direct-fit bars designed specifically for 2021+ Broncos. Combo beam pattern (flood + spot) with OSRAM LEDs at 5700K color temp.
50" Specs:
  • 22,680 raw lumens
  • IP68 rated
  • 50,000 hour LED life
  • High/low brightness modes
  • Includes snap-on debris cover
40" Specs:
  • 17,640 raw lumens
  • Same IP68, LED life, and features as 50"
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting Bronco_Light_Blog-2
Available with Upfitter Package pigtail harnesses for factory switch integration. For non-Upfitter builds, there's a direct-fit switch panel option. Kits include installation guides, adjustable brackets, and drill fixture templates.
3x3" Ditch Lights
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting P1043743
Ditch lights for peripheral coverage. Mount to existing hardware, available in spot or flood patterns.
Specs per pod:
  • 4800 raw lumens
  • 5700K OSRAM LEDs
  • IP68 rated
  • Black powder-coated stainless brackets
  • Weatherproof wiring + backlit rocker switch included
Spot pattern for distance, flood for technical terrain. Upfitter-compatible harnesses available.
Bumper-Mounted Options
Six-Pod Kits (Modular and Standard Bumpers)
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting BNLT-BR-21M-B6-CFG_img_10
Four flood + two spot configuration for balanced output. 4800 raw lumens per light at 5700K. Powder-coated stainless brackets with black end caps. Weatherproof harness and backlit switch included.
Bumper Fog Lights
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting Bronco_Modular_Blog-1
For modular bumper setups, dedicated fog lights fill the low-position lighting gap. This direct-fit kit combines two flood beams for close-range illumination with two spot beams for distance projection.
Specs per pod:
  • 4800 raw lumens
  • 5700K OSRAM LEDs
  • IP68 rated
7" Round Bumper Lights
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting Bronco_Modular_Blog-5
Specs:
  • 5800 raw lumens per light
  • Selectable white/amber DRLs
  • Low/high brightness modes
  • Two-axis adjustability
  • Includes protective cover
Bumper Light Bars
30" Modular Bumper Bar: 13,860 raw lumens, combo spot/flood pattern. Black reflectors, includes cover.
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting BNLT-BR-21M-B30-CFG_img_8
20" Standard Bumper Bar: 8,820 raw lumens in a more compact package. Same combo pattern and cover protection.
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting BNLT-BR-21S-B20-CFG_img_10
Electrical Support Accessories
Bus Bar Kit
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting BNLT-BR-BUS-21_Header
Direct-fit power distribution for 2021+ Bronco and Bronco Raptor. Bracket mounts in driver-side fender. Handles lights, compressors, and other 12V accessories with properly sized battery cables.
Battery Relay Holder
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting Bronco_Light_Blog-3
Powder-coated mount for organized relay installation. Reduces loose connections and simplifies troubleshooting.
Switch Panel
Ford Bronco Borne Off-Road Direct-Fit Bronco Lighting Bronco-Light-Blog-5
For non-Upfitter Package builds. Five customizable switch slots, no cutting required. Maintains factory USB functionality.
Hope everybody has a good weekend! If you have any questions about anything in our Bronco lighting line-up, don't hesitate to ask!
-Josh
Status
