Utah Bora spacer trade?
Mad Max
James
Southern Utah
2024 Bronco
I have 1.25" spacers on my Badlands Sasquatch. A little more poke than I want. Would anyone with 0.75" Boras be interested in a trade straight across?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
You’ll have to cut the rear studs with anything less than 1.25”
Montana Bronco
Montana
Chevy
That is not true.
OP says he has Sasquatch, and those wheels have little “pockets“ for the rear studs. In fact, all of the factory OEM aluminum wheels on Bronco’s have those same “pockets”, so .75 wheel spacers will work fine.
The only factory OEM wheels that require a minimum of 1.25 are the steel wheels on a Base or BD.
redone17
Cold Spring, NY
That is not true.
Ah, right. Sorry for the misinformation. I’m a steelie guy.
Mad Max
Mad Max
James
Southern Utah
2024 Bronco
They're gone--and the 0.75" seem to work now.
