Bolt-On Reverse Light Kits
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Did you know we have a few reverse light kits that we offer from Baja Designs?
First up, is the Baja Designs Spare Tire Reverse Kit
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco/
This kit includes a bracket that mounts to your spare tire. It keeps a pair of S1/S2/Squadron lights up high away from the ground (good if you off-road a lot and are worried about something hanging from the bumper).
The bracket included with the kit bolts onto the 3 factory lug nuts that hold your spare tire on (they provide extensions in the kit for the bracket). A harness is included that let's you run the power line up to your factory upfitter/aux switches (or if you don't have those, you can opt for their toggle switch harness). One tip is to just route the wire to your rear passenger panel, where Ford has already ran a pass-through wire for you (this is just a wire that is pre-run and goes into the passenger front kick panel, where you can then connect it to ANOTHER wire Ford ran for you that goes into the engine bay).
You can also add on an optional license plate mount to also keep that license plate up high (pictured here)
Ford Bronco Bolt-On Reverse Light Kits 1646837147313
Next up is a kit that we put together ourselves. Our Baja Designs Reverse Light Kit
https://www.4x4truckleds.com/2021-ford-bronco-reverse-light-kit-w-baja-designs/
This kit includes mounting brackets from KR Off-Road (the manufacturing side of our business). It allows you to mount the lights below your bumper in a variety of heights. You can mount them hanging way down low OR you can have them tucked right under the bumper (which DOES put them out of the way of hitting anything, as you'd hit your muffler before you hit your reverse lights).
The main different with our kit is that we also provide you one of our CrystaLux harnesses (CrystaLux is another in-house brand focusing on LED replacement bulbs and harnesses). This harness taps into your factory reverse circuit so that your lights come on automatically when you go into reverse. On top of that, we also allow you to also control the reverse lights from a factory upfitter switch. So now you can turn those reverse lights on from a switch (one tip is to get some amber covers, throw them on the reverse lights and now you've got chase lights for the trail!).
This is the kit we run on our demo truck since it keeps the lights tucked up under the bumper and less visible.
Ford Bronco Bolt-On Reverse Light Kits 1646837332825
These kits are all in stock and ship within 24 hours (orders placed before 1pm EST usually ship the same day from our warehouse)
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
How much extra work is it to use your spare tire? Do you need to carry extra tools in case of a flat?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Just an extra socket for the extension bolts (as they use a different size then the lug nuts). That's it. Otherwise you just remove the same 3 lugs when you need to access your spare. The baja lights have a quick connect plug on them, you just unplug it and you're good to go.
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
I originally thought I wanted the spare tire mount for the reverse lights but decided to go with the KR under-bumper mount, and for the reasons given above by Adam (OP).
I’m so far very happy with the bumper mount. As stated, the lights are up higher and better protected than pictures seem to indicate. The wiring took some time to tuck up neat and you do need to remove the rear tail light if you choose to tap the reverse light circuit at that location. I enjoy the DIY stuff, however, and I now have the option to switch the lights on from an Aux switch as well as them coming on with the OEM reverse lights.
I’m sure you’ll be happy with either solution, though.
2ndGenBroncoOwner
South Carolina
2020 Ford Expedition Platinum
You guys are awesome! I couldn't be happier with the service, support and communication from @4x4TruckLEDs.com. I have installed the A-Pillar Squadron Pro's, the Reverse Kit for the Spare Tire and yesterday, I just received my KR Bevel kit for the Fog light kit in the Mod Bumper. Easy installs all around. Now if I could only find the factory replacement light switch that had the front and rear fog buttons to use instead of the upfitters....
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We ordered ours months ago. Still waiting for it to come in
mhorvath1218
2022 Bronco Badlands
Is there any plans to make a kit with DD SSC2 or SSC1 with the red backlight? That way they can come on as red taillights then switch to white for reverse or manually
Headsong
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If we did that we'd want it to be plug and play so you didn't have to splice anything. So right now, no it's not available. But we might do it one day. I need to figure out which connector the F150s and Broncos use (same connector) so we can develop a harness
Ksjrb03
Tx
F250
How did you route power to the bumper mounted lights? I currently have my rear panels removed for another project and saw an orange/white wire which can be used to get me to the upfitter switches in the engine bay. Curious if you used this, and how you routed out of the cab down to the bumper. Want to pre run the wire for reverse lights while I have things torn apart, but I didnt see easy access out of the cab.
BostonGuy
Boston
Jetta
Anywhere to see the install instructions for the under bumper wiring? I haven't wired anything on the Bronco yet. or any other car for that matter.
xusarmy
Todd
TX
2021 Ford Bronco Outer Banks
I put in rear flood lights on, there is a plastic panel after you open the tailgate, remove it, and there is a little hole at the bottom that I ran my cable through and up. Found a great ground to tie into and then connected the power to the Orange/White wire. Now you have to connect the Orange/White wire to either the brown/white wire in the glove box to eventually tie it into one of your AUX switches. I tied mine into AUX 6. The most difficult part was tying the wires behind the glove box together. Ford doesnt provide ample room to do this.
Ksjrb03
Tx
F250
Ya, I removed that panel when I wired my Curt 4 pin. I know you can get up in there from the bumper, but don't remember there being a pass through from there inside the cab to the orange/white. I will have to look again, thanks.
And ya, I saw the wiring points behind the glove box when I was doing a speaker swap and remember thinking, that will be fun when I need to use those. Pretty silly how short they left them.
BrentC
Brent
Calgary, AB
I see responses to your question above this response which may be more helpful. In my case, I had the pre-spliced cable from 4x4truckleds.com that I ran from the engine compartment. I zip-tied it to the frame using heavy duty ties back to the driver’s side tail light. I then took off the tail light following the instructions from the service manual that a kind forum member sent me, and spliced the diode-protected leads to the reverse light circuit. The backup lights come on with the reverse lights or with the upfitter.
You can get advice and help from the supplier of your lights, or from some reading on this site. Good luck!
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
why does the spare tire option have the note that it’s “not for Sasquatch equipped vehicles”? Is there a specific Sasquatch link to product?
