BNSF Tracking
rainman23
Ray
Salem, OR
F-150
Anyone have access to BNSF tracking that wouldn’t mind running my railcar or VIN for a status update? Thanks in advance!
okbob
North of the Red
71' u15, 66' u14, 66' u14
Do you have the CSX rail car number from when it left Michigan? If so, call the BN 800 number and it will give you an update, I did last night for mine.
rainman23
rainman23
Ray
Salem, OR
F-150
I’ve been using that, but it’s saying my railcar has been sitting the past two days in the same spot about an hour away from final destination. Really wanted an ETA and to make sure everything is still “on track”. Sorry, I had to.
Kameronatm
Kameron
Bronco Badlands 4dr
What # did you use? I thought the csx 800# is the one to keep using?
rainman23
rainman23
Ray
Salem, OR
F-150
Same, I’ve been using the CSX number. Is there a BNSF number too!?
Rex21c
Joel
Canby oregon
2016 fusion energi
you keep using the CSX number as the number matches the car it's on. When it went to BNSF it didn't change cars. It could be sitting because the rail yard is backed up. Actually your bronco is probably the same train as mine, and I can tell you it IS backed up in Portland. Should be unloaded any time. Then it's a waiting game for trucking to deliver it to your dealer, which could be 2 - 10 days from info I've gathered around the Portland area.
okbob
North of the Red
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
My railcar spent 3 days in Portland before heading to Kent,Wa. Normal stuff
rainman23
rainman23
Ray
Salem, OR
F-150
That makes sense. Thank you!
Kos
Omaha, NE
2022 Ford Bronco Badlands
The PNW rail network is extremely congested. Sitting a few days is on par.
Rgarrison58
Roberta
Climber1958
Toyota 4 Runner
I’m not having any luck getting an updated status of the rail car my bronco is on. CSX status only tells me it was transferred to BNSF on 4/1 with no ETA available. My dealer is in Kent WA and they still have a 4/8-4/14 delivery but they can’t get a status. Were you able to get a status of the rail car on BNSF?
72BroncoSand
PNW
Whats your railcar number? I can give it a try for you. To answer your question, yes I was able to track its progress on BNSF tracks
HotShotGamertv
FORD
Who’s else is with my Bronco 🐎?
My Rail Cart BNSF303020
