BluMak3D Ditch/Deer Lights Updated
bryan@blumak3d
blumak3d.com
93 Cobra, Z4M, K1600GT, R1300 GS
Hey all. We recently updated our Ditch Lights for Baja Designs S2 to make them adjustable.
They now articulate more than 45º for use as Ditch or Deer lights depending on your needs.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Nice! Can we see some pics of them used on the Bronco? Thank you.
bryan@blumak3d
bryan@blumak3d
blumak3d.com
Is there a way to mount like a rigid 360 4" to the top?
The top of our bracket is identical to the top of the mirror arm housing so anything you would’ve mounted on top of the mirror arm can go right on top of our bracket.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Dang - I just bought these mounts. Assuming I didn’t get the adjustable version - I didn’t open the box yet. (I was the guy that asked you to set up a mount only link).
bryan@blumak3d
bryan@blumak3d
blumak3d.com
I haven't shipped any adjustable Ditch/Deer units yet.
The new adjustablity feature allows them to project higher than the Ditch Lights, but not any lower.
We put a lot of R&D time into perfecting and maximizing the projection angles of the Ditch Lights (as we do with all of our products). If thats what you are using them for, adjustability is really unnecessary...but, If you actually need the adjustability (in order to raise them), and want to ship them back in excellent condition, I will exchange them with an adjustable set.
PM or email me if you want to proceed with an exchange.
redone17
Cold Spring, NY
I think I’ll just stick with the original. Thanks for the offer.
How well do these plastics hold up to sun and salt?
bryan@blumak3d
bryan@blumak3d
blumak3d.com
The material is Nylon (PA12). The material is sensitive to UV (in extremes, over time) but the SEM Black Trim we apply negates that. If the coating gets damaged, you can easily apply a fresh coat. This is the same coating that many OEMs use on their trim pieces that are made from plastics.
