BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights
Caleb@PandaMotorworks
Caleb
St Louis MO
Ford Bronco BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights 24_ford_bronco_form_taillight_creative_33 (1)
Form Lighting - 2021+ Ford Bronco LED Tail lights
Ford Bronco BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights 473002824_10227257122229266_8744948029356409401_n
Are you ready to take your Ford Bronco to the next level? Look no further than the Sequential LED Tail Lights from Form Lighting. These premium tail lights are the perfect upgrade for any Bronco enthusiast, offering a sleek, modern appearance paired with enhanced functionality. With quick and easy plug-and-play installation, you’ll be turning heads on and off the trail in no time.
Stand Out with Modern Styling
Unlike many aftermarket options, these Sequential LED Tail Lights are designed with factory-style optics that deliver a smooth and even illumination. The outer perimeter of the lights shines as a solid bar for running and brake lights, while the inner section features three vertical bars for the running light, brake, and turn signal.
Plus, with the choice of smoked or red lens styles, you can customize your Bronco’s look to suit your personal style.
Ford Bronco BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights 2024_ford_bronco_form_tail_lights_comparison_collage_-_red_vs_smoked (1)
Packed with Advanced Features
Optional Startup Sequence
Add a wow factor every time you turn on your running lights with the optional startup animation. The outer C-bar lights up in a dynamic chasing sequence, while the inner vertical bars illuminate outward. And if you prefer a more traditional look, disabling the feature is as easy as unplugging a connector during installation.
Selectable Sequential Turn Signal
Take customization a step further with the selectable sequential turn signal. Each time you activate the turn signal, the three inner bars sweep outward in a smooth motion. You can even choose between amber or red sequential lighting—or switch to a static turn signal for a cleaner look.
Increased Reverse Light Output
With four individual optics, these tail lights provide a significant boost in reverse light brightness, offering superior visibility compared to factory halogen models.
Ford Bronco BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights 2024_ford_bronco_form_tail_lights_comparison_collage_-_functions (1)
Effortless Installation
Forget complicated installs. These Sequential LED Tail Lights are completely plug-and-play for both OEM halogen and LED models—no splicing or specialized software required. Simply remove your factory tail lights, pop these in, and you’re good to go!
Additional Installation Highlights:
  • Includes a harness for halogen models to power the brake signal.​
  • Fully compatible with the Bronco’s blind-spot detection system, eliminating errors, flickering, or hyperflashing.​
Ford Bronco BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights 2024_ford_bronco_form_tallight_whitebox_kit_-_labeled
Why Choose Sequential LED Tail Lights?
Features at a Glance:
  • Direct OEM replacement for 2021-2025 Ford Bronco tail lights.
  • Smoked or red lens options to match your style.
  • Selectable red or amber sequential turn signals.
  • Increased reverse light brightness.
  • Optional startup animation.
  • No blind-spot system errors—fully compatible.
  • Plug-and-play installation.
  • Exception product warranty
Ford Bronco BLOG: Upgrade Your Ford Bronco with FORM's Sequential LED Tail Lights 472810984_10227257122629276_2907543121824874388_n
Fitment
Designed specifically for the 2021 - 2025 Ford Bronco, these tail lights are the perfect addition for anyone looking to enhance both the aesthetics and functionality of their vehicle.
Why Wait? Upgrade Today!
Don’t settle for ordinary when you can have extraordinary. The Sequential LED Tail Lights from Form Lighting are the ultimate combination of style, performance, and practicality.
Turn your vision into reality—upgrade your Ford Bronco now!
Available for purchase HERE ⬇
https://www.pandamotorworks.com/products/2021-ford-bronco-tail-lights?_pos=1&_sid=a1e684211&_ss=r
