Sold: Indiana Black First Edition Dash Upper/Lower
87 BAJA
Stroppe
Craig
Ft Wayne
25' STROPPE , 24' Sierra AT4X Duramax
Stroppe
Brand new Ford OEM Bronco upper and lower right/left dash Black First Edition. Will fit all broncos full size not the sports. Asking 440, cost almost 600 from Ford Parts.
Ford Bronco Black First Edition Dash Upper/Lower IMG_6650
Ford Bronco Black First Edition Dash Upper/Lower IMG_6652
Ford Bronco Black First Edition Dash Upper/Lower IMG_6649
Ford Bronco Black First Edition Dash Upper/Lower IMG_6651
Ford Bronco Black First Edition Dash Upper/Lower IMG_6648
JBach
Jeremy
wisconsin
You’re about a week late posting this. I just ordered all these parts from ford otherwise I would have bought them.
87 BAJA
87 BAJA
Stroppe
Craig
Ft Wayne
Stroppe
If you haven’t got them you could cancel your order and I could make you a deal
JBach
Jeremy
wisconsin
Was the piece that you had for around the start button a slightly different color than the dash
87 BAJA
87 BAJA
Stroppe
Craig
Ft Wayne
Stroppe
Yes very slightly, Welcome to the word of ford and their manufacturing process. It so minor once you have them installed. They are not right next to each other so you cant tell a obvious difference. If you really want to go down a rabbit hole grab a led flash light and look at all the plastic trim in your Bronco none is the same shade of black/blue/grey. Ford really dropped the ball on their interior design i think their interior designer may have bee color blind.
JBach
Jeremy
wisconsin
The one I got almost looks like it’s been painted. But it also has a different part number than the one that you had in your pictures so I was thinking about ordering the one that you had and seeing if it’s different. yours was black right?
87 BAJA
87 BAJA
Stroppe
Craig
Ft Wayne
Stroppe
yes it was black
JBach
Jeremy
wisconsin
Ok. Thanks a lot for the info
87 BAJA
87 BAJA
Stroppe
Craig
Ft Wayne
Stroppe
You could always send what you got back and get a good plastic adhesion trim paint and paint them black, I'm thinking that what ford actual may do way some of the parts look. the sandstone Wildtrak dash looks to be painted as the bottom looks to have overspray from the top and a slight different shade of color.
JBach
Jeremy
wisconsin
My was a different part number for the bottom piece then the one you listed. It is black but has a glossy finish. The dash part is the same part as yours but is more of a flat black. Is your bottom piece more flat or glossy?
