BL non vs SAS
Area51BS
Ron
Badlands non SAS 4dr 2.3
What are you really getting for $4k adding SAS to a Badlands?
BL has front/rear lockers, ADV 4x4, rims, tires, gears, shocks and springs. It’s not like you get them with SAS. You get a slightly different rim, tire size, slightly different shock/spring and a slightly different gear. What makes it $4k more?
stickshifthappy
RVA
Ford Ranger, 65 Mustang
From a purely off road capable vehicle it’s really just the bigger tires isn’t it ? Especially if you have a manual.
specific fender flares aren’t really something that’s gonna make me drop more cash than I need to.
Baja71
Stroppe
tw
Dallas, TX
1971 Stroppe Baja
Stroppe
I already had rims and tires I was going to use from another rig so I skipped the SAS. Gratuitous photo attached. 😁
Ford Bronco BL non vs SAS 1721E142-5C89-4942-9CD9-7BCB442A60A7
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
My memory was $2,500
1/2” wider wheels beadlock capable
35” wider tires
Extendo rear camera to see better and different spare carrier very slightly different for brake light and stopper on the bottom.
kojack19
CT
Ford F150 Raptor
You nailed it on the head. Short answer is not much. Suspension is almost identical. If you get a manual you get 4.7 gearing and if you want an auto you are still more than good. If you get an auto with sas savings is less but still better IMO.
I don't like the sas wheels and they are heavy and the sas goodyears wouldn't be in my top 12 tires for this truck.
Flip the stock wheels and tires for 1000, spend around 2800 -3k for new wheels and tires, sas flares if you want them for 350.
Savings is even greater for those of us that were in Wildtraks that opted to drop down to Non SAS Badlands.
Compta38
Alabama
Ford Fusion
35” wider tires
It is $2500...what folks don't notice is the price for automatic transmission goes to $0 on Badlands when Sasquatch is added.
Ford Bronco BL non vs SAS Screenshot_20220624-172747__01
Murph914
Franklin, MA
Ob I figured it would be something like that. I went with the non sas bl with optional rims myself.
I will add that the blue trails locally are just at the tip of what I’m comfortable with. The sas builds do not scrape nearly as much and just that tiny bit of clearance makes a difference. I’m leaning more and more towards 35” rubber when these wear out.
