Deebocubs
Deebocubs
Matt
Chicago
Link to items? Looks pretty cool.
Bestop 8003315 Wrap-Around Windjammer for 1997-2002 Wrangler
RERPRO Trunk Cargo Cover for Ford Bronco 2021 2022 4 Door Rear Trunk Security Shield Shade Luggage Tonneau Cover
Greasyfingers429
Adam
RI
VW Jetta TDI, Range Rover Sport Td6
Very nice. Can that Rampage top come completely off and store on-board under the tonneau?
I am running tube doors all summer, factory soft top removed, with the Ford tonneau. I bought a cheap bimini top on Ebay, for the unexpected rain shower, but keep it folded up in the back most days. Problem with that bimini is that it’s got a gap over the visors where rain will still enter. And it will collect a pool of water since there’s no center support.
jayson
2023 Bronco BlackDiamond SAS 4DR HT
Looks great! Did you use the Windhammer made for the Wrangler? Actual links you can provide?
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Deebocubs
Deebocubs
Matt
Chicago
4 bolts and two straps to remove the top but the front hardware doesn’t fold up and store in back. You may be able to remove the top skin and keep the hardware in without the top but note sure how the brackets look without top on and if it is noticeable.
Deebocubs
Deebocubs
Matt
Chicago
EgreenBadSquatch
Washington
2015 F-150, 2022 Badlands Sasquatch
Works good enough. Appears rainproof for the most part. Rampage trail view as
Bikini top, Jeep windjammer, and Bronco vinyl tonneau.
Does the windjammer wrap around the roll bar? I’m curious how it attaches. Would you be able to have that and a mesh top at the same time?
Etienne
Etienne
Mooresville NC
'75/'89 Chevy K5 Blazer
Best option I've seen from the aftermarket so far... As others are asking on this thread as well, please forward a product link if this is Bronco part, not a retrofitted Jeep bikini top.
dmhalka
doug
Audi
so all the tonneau covers that i've seen have straps that go over the outside of the rear tailgate. is this one different or did you modify it? there's no links to the specific one you say you used, but when I googled it all the options i saw had the straps over the tailgates.
Deebocubs
Deebocubs
Matt
Chicago
Not sure how the mesh works yet. I have that top too and have not had a chance to install it with this setup but the Jeep windjammer straps wrap around the center roll bar. I had to extend two straps on the jammer with Velcro straps in center. 2 of the corner straps fit around roll bar. Inside sides of windjammer ore not attached and so far no flapping at high speeds.
Deebocubs
Deebocubs
Matt
Chicago
The rampage top has windows and tailgate bar. So the tailgate bar helped hold the traps into the trunk.
