Biggest replacement tire on Badlands?
rinconryder
Wes
Santa Barbara
'16 F150
This is probably buried somewhere in here so I apologize. I am on the fence whether sasquatch is too much as the standard Badlands seems just right in SOME of the photos that I have seen. If I were to order the standard badlands what is the biggest tire that I could get in there if I wanted to replace the tires with larger tires?
Toccoa
Isuzu Rodeo Sport
Add a lift and you can add just about anything (within reason). It's speculated that a 35" tire might fit, but as there are no Broncos on the road, we don't know.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
King of the Hammers (KOH) thread shows 35s on standard BL... which should help give some insight.
Gamecock
I think you'll have to see....with stock wheel offset and no more lift, any more than stock 33s will be an experiment as to whether you rub at full lock. With a little less offset (match Squatch wheels), and a 1/2' more lift (level the front)..35s.
soonerbronco
Noah
Knoxville Tennessee
1976 FJ40
I'm planning on 285/75/17 (on the upgraded 'bead locks'.....) I'm about 90% sure that they won't rub under the vast majority of on and off-road driving. I can't stand the giant SAS flares, but I do want a bigger (34.4") than stock tire.
