Bigger tires & speedo calibration?
umpire19
Ron
Pittsburgh
Ford escape
If I put bigger tires (33's) on my BB do I need to do have speedometer recalibrated?
Woody '73
Audi A6, Bronco on order...
Yes. Larger circumference of the tire means it takes longer to complete a full rotation. Speedometer will read slower and odometer will clock less miles.
BroncoAZ
Mitch
And the problem with that is what, exactly? The bigger issue is recalibrating for the auto trans.
Woody '73
Agreed. Just answering the question about the speedometer. :)
kodiakisland
Arkansas
Need to? No. You may want to however. Lots of us with 4wds add bigger tires and don't worry about it. My tires add about 4mph at highway speeds. I can do the math on the fly. Or not. I rarely look at the speedo anyway. Yeah, sure, my odometer will also be slightly off, but I don't care. Oil change intervals aren't that sensitive. Overall, I just don't care.
BR0NCO
Randy
Mass
Jeep Audi
It’s a good idea with an automatic transmission to get the shift points back to where they should be
kodiakisland
Arkansas
I don't own an auto, but are you saying today's autos shift based on MPH instead of RPMs?
BroncoAZ
Mitch
Today’s autos take a lot of parameters into consideration. If the tires are significantly larger the auto might not be able to respond correctly when picking a gear to downshift, and maybe it drops 2 gears instead of three.
EStepCG2022
Chicago
2005 Cadillac CTS-V
Wouldn't the car's MPG readout technically be off too? I would assume it just uses the odometer mileage data to track that.
Big Boss
Outer Heaven
Bronco Big Bend
The MPG readout is already off LOL. Mine has not been accurate since day 1. Always 2 to 3.5 MPG optimistic, compared to hand calculated
EStepCG2022
Chicago
2005 Cadillac CTS-V
That's probably true, but my point still stands that the readout would be further affected by a tire size increase.
