Big Bend Tires 33s?
OB1
Sean
Long Island
Jeep
Hey guys! New to the forum, ordering a Big Ben. I'm sure you all have already discussed this but I wanted to ask. I want to upgrade the Big Ben wheels and tires. They come with 32" but the only other option is 35s? Do you think I would be able to get the 33s? I think it be give it the best stance. 35s might be too big, I think. This will be my daily driver and I don't rock climb. Thoughts?
Toccoa
Isuzu Rodeo Sport
Ford Bronco Big Bend Tires 33s? 1600803288757
broadicustomworks
Hanging Rock, North Carolina
I see no mechanical reason why you can't go 33's on the Big Bend. I mean, you may or may not be able to order them from Ford.
We will know for sure when the Build and Price comes out.
At the end of the day there isn't a lot of difference there.
Philly
Dallas, TX
2022 JL Rubicon
I believe at the last Bronco event in Colorado a Ford rep said that only the Badlands will be available with 33" tires.
That being said, I am sure many Badlands owners will sell their factory wheels and tires in order to get unique wheels when they upgrade to 35's. You could pick up a new/used set and throw them on no problem. You may have some rubbing though because the Badlands has a different suspension.
The Driving Viking
Northeast
2022 Bronco Sasquatch 2022 Willys Xtreme Recon
Unfortunately I'm thinking your going to need a 1 inch lift or at least bump stops to make it work. Especially if your going off road.
The extra with is most likely going to be the problem and you'll be dealing with rubbing. The Badlands comes with 33s but it has taller stiffer suspension.
With that said nobody knows for sure until these Broncos come out and we get to tinker with them in the wild.
_2020_
Sylvain
MA
2014 Mini Countryman S , 2015 JKU, 2017 X5 3.5i
If its for the look only, maybe 1” spacers and the stock wheels will look a little beefier and its enough!
RG7
B8 A4, 2018 Triumph Street Triple R
You can buy 33’s for your Big Ben but as of now you can’t spec it from the factory like that. Would imagine 33’s will clear without a lift but again we won’t know until people start taking delivery and seeing what works and won’t work without lift etc.
Garemlin
Delaware
I plan on going with 255/80/17 33x10 pizza cutters. It's only going to add a half inch to the sidewall so I'm hoping it will work. Not messing with the width.
Orbiter
Honda Pilot
Same plan here for the BD. Hoping the stock wheel wells will work with 33x10s.
N3T
Ed
Detroit
95 e320 wagon
You do realize it comes with 32.6” tires and you’d gain something like 0.6” by going to the 33s?
