BIG BEND (sas and mid) vs BLACK DIAMOND (mid only)
Dr.Z
Phoenix
I’ll likely be between these two possible set ups.
2 door Big Bend with Sasquatch and Mid
Or
2 door Black Diamond with just the mid.
the Sasquatch package just looks great. Won’t be off roading every weekend or anything, it will be a DD. Thoughts on if the Sasquatch package will affect gas MPG ?
just looking for some 2 cent. Thanks.
zaki
'19 Lexus LS 500;'94 Acura NSX;'13 Landcruiser
I have finally settled on the Black Diamond with Sasquatch and Mid Package. The color choice is VERY difficult but narrowed down to the CG vs Area 51.
Scohin
Ford Fusion
Or
If you're looking for MPG leave the Sasquatch a myth lol
Laminar
Iowa
Cougar
I like Black Diamond with mid. Rear locker is enough to get me out of any situation I would find myself in, lighter weight front axle is just fine, and I can put whatever tires I want on it if I want to move up in size.
It has the rock rails, heavier bumper, and crash plate so it's got some light offroad protection.
BD with 32s is for sure getting better mileage than the Sasquatch. For the same tire brand, the 35s weigh 20lbs more than the 32s...EACH.
Dr.Z
Phoenix
Yea I’m thinking I want the BD for the vinyl seats, will do Mid package then will upgrade tires / wheels accessories in the future.
Trainer14
Tom
2014 Escape 2.5 and 2020 F250 7.3
I'm torn between the Big Bend, Black Diamond, and the Outer Banks. I will be adding a hard top. With the BB and BD I would be adding the Mid package (need Heated seats!!!) but for the cost to upgrade from BB to BD for skid plates (std) or upgrading to OB for Mid (std) and no manual available. May just go with BD and add wheels at a later date.... Hmmmmm....
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Black Diamond with mid for me. I only want the looks of the Sasquatch, which I'll add with bigger tires and a 2" lift later for less money.
Dr.Z
Phoenix
What part of the country are you in?
BOLD Renegade93
Bossier City, LA
zaki
I would agree with you if the Sasquach package did not add some items that really allow the Bronco to do what it is capable of. Besides the 35" inch tires you are getting some serious off road ability with the electronic locking front and rear axles, 4.7 drive ratio, high clearance factory suspension (under factory warranty), position sensing Bilstein shocks and high clearance fender flares. Even if you do not intend to go rock crawling, I certainly don't think I will do much more than dirt or gravel, the Sasquached Bronco just manages to look so handsome and at the same time brutish and bad ass. It just comes alive.
For my money unless this package is priced over 7-8K, it is the one extra I would no forego.
Besides the capability, remember that the Bronco's looks just go to a different level with this package and what is the value of feeling like a million dollars every time you look at your awesome ride and to know what it can do. Priceless :)
Dr.Z
Phoenix
I think you could probably achieve the same look within tires and an additional mod or two at most... probably not worth the $ of you won’t use it hard
tripjammer
tripjammer
2021 GR Supra 3.0 Premium
Depends on the price of the Sasquatch package. Some are saying it's not over $4k. If so it's a no brainer since you will get the warranty....and the perfect look.
Dr.Z
Phoenix
IMO... it will be pricier. But that’s just me. Saving significant money via tires and a 2 inch lift.
