Beadlock ELI5
fronc
Frank
San Mateo, California
www.instagram.com
2021 First Edition | 4 Door | Cactus Grey
Hi all - I understand that my upcoming FE will have "beadlock capable" wheels, but truthfully, I don't know the first thing about whether to actually convert them to beadlock. Is that only for off-roading? Are there downsides to running beadlock all the time? How do you convert it, and can you do it yourself? I literally know nothing except for "beadlock wheels keep the tires on the rim when running under low PSI for rock crawling". Can anyone Explain Like I'm 5?
Judge Rufus
Wheeler
Colorado foothills
Infiniti QX80, GMC Sierra, Mercedes SLK32 AMG,
Rivers90
Ben
Southern California
2 Door Base Sasquatch
There is no advantage to beadlocks on the street.
I run my tires all the way down to 9 psi without beadlocks when off road.
As you go lower and lower in tire pressure at some point the tire will come off the bead particularly as you are turning.
But you would need to be in some extreme mud or sand to really need to go that low.
Most of my off roading I am at 15 psi.
On the street you want to be at the factory recommended pressure.
RG7
B8 A4, 2018 Triumph Street Triple R
Beadlock rims are not legal for daily driving.
Won’t matter unless a cop is looking to nail you to the wall for something else you did.
OP I’ll answer your questions in order.
1. Yes. 0 benefit on pavement (unless we’re talking about drag cars but I won’t even get into that)
2. Not driveability wise, but the reliability downside is if you pop a tire and your spare tire and need to have one changed, most regular tire shops won’t go near beadlock wheels so you could be SOL unless you find an offroad shop that will do it for you.
3. Installation involves debeading the tires and can be done at home, but not something I’d do if you aren’t comfortable mounting a tire to a normal wheel
Bottom line is if you’re just getting into offroading it’s an awesome option to exercise down the line, but not something essential if you’re starting out.
fronc
fronc
Frank
www.instagram.com
Thanks for the complete and thoughtful answer! I don't think I'll be needing it anytime soon.
May your Broncos be with you soon.
