Base Radio System Flash or not?
Bronco671
Tim
Washougal
69 Bronco, Ram 1500
I have read most of the thread regarding the sound system upgrades/modifications. There is clear instructions that the head module needs to be flash per the instruction printed on the JBL sound bar information sheet. I have also watched the videos on youtube with both of the installs flashing the head module with the Ford system computer.
My question is there any clarity that this will work to allow more power to the back speakers. I realize that the 4 inch paper speakers are just junk.
If this works seems to me that this issue could be fixed very easily. The JBL sound bar has nothing to do with the flash requirements, is not blue tooth and connects to the rear pod speakers directly.
Headsong
The other 14 page thread too overwhelming? LOL....yes, I agree. Give it to us simple:
WuNgUn
Ontario Canada
2 door Squatched
Dealer would probably charge you for the flash, if they agree to do it without the hardware upgrade. Or spend the money on a OBD dongle, a free ForScan license and do the 3800 mod... And access 100's of other configurations on the Bronco as well. 🤷
da_jokker
Jeep Wrangler JKUR
Yeah there's definitely more to the JBL flash than the Forscan trick....however if the goal is simply to increase the output range of the rear speakers, the sounds like forscan is the way to go (unless your dealer will do the flash for free)
Owning a Bronco without Forscan seems like a bad idea... you'll eventually need it anyway.
Busterbronco1
Andy
2005 Mustang GT Premium and 1982 F100 Short Bed.
I am curious what Forscan is the most recommended one? are there any suggestions or links?
Bradnewt
Brad
Hot Springs, Arkansas
Jeep Wrangler
go to the Forscan website and they have two recommended cables available on Amazon. One has a manual switch and the other switches automatically. I purchased the automatic one and it works fine.
Abecker
Aaron
2022 Ford Bronco 2dr
Can you elaborate on the “3800 mod?” From what I’ve found so far, forscan alone cannot flash the speakers.
WuNgUn
Ontario Canada
2 door Squatched
Abecker
Aaron
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
I'm replacing the dash speakers and the rear speakers next week. Also adding a sub-woofer. Since the Forscan mod adds full range to the rear speakers, I think I'll hold off and see if the sub rounds out the sound without the flash. If you haven't seen the Youtube video from BudgetBronco, replacing those speakers looks really easy. I'll find out next week :)
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
Yes I have already upgraded all speakers. The 4” were replaced with kicker 2 ways and the kick panel speakers I replaced with kicker 6.75” subwoofers
That's an awesome idea for the kick panels! I have one of those Kickers in my Element and it sounds great for a small sub. Did you have to any modification to fit them? How much power are you running to them?
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Think the average joe can figure this Forscan stuff out? Or do you need to be a computer programmer type?
WuNgUn
Ontario Canada
2 door Squatched
Nah, we all started out knowing squat 🤷
Good tutorials here and elsewhere.
Backup your modules and have at it!
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
I just did the 3800 mod to the speakers and have upgraded all to Kickers. Makes a huge difference.
Blaven
Pennsylvania
The Forscan mod did nothing for my rear speakers after upgrading the front and back to Kickers.
