- #16
That's what I was thinking just grind them off to service the bar if need beEasy enough to do. It is only spot welded on there. cut the spot welds and will come right off.
Can you order these brackets separately? Or do you have the spare set still, I could buy from you? Do you think they would work with the Modular bumper with some modification? They look more beefy than the LOD brackets that are available.I order those reinforcement brackets separately not realizing the kit came with them. They really beef up the mounting.
I wanted to cut the mesh plate out but not the tube itself though.
I used the ones that came with my kit. You can get these hereCan you order these brackets separately? Or do you have the spare set still, I could buy from you? Do you think they would work with the Modular bumper with some modification? They look more beefy than the LOD brackets that are available.
I got these duel beam lights.What fog lights did you go with?
do you need to relocate cameras or acc?
How do the lights fit? The angle of the cutouts make it look like they would point to the outside so are they staight or do they have a mount inside to pull them in some?I got these duel beam lights.
https://www.led-colight.com/products/3-inch-db-p-series-dual-beam-yellow-white-fog-lights-pods
Not a fan of the white spots as they are spots even at 100 yards as spot. The low bean fogs are really bright and project far.
The camera was an addition to the base sqatch
From ebay
https://www.ebay.com/itm/3544042458...4msHm3HQJq&var=&widget_ver=artemis&media=COPY
No Accessories needed to be moved or replaced.
The HD has a mount. But I had to design and 3d printed my own brackets for it. As the brackets it comes with (the light) need to be supported from the bottom as the Bumper has the mount on top to hang it from the inside. So instead of buying new set and figuring out it would fit I just made my own and printed a set.How do the lights fit? The angle of the cutouts make it look like they would point to the outside so are they staight or do they have a mount inside to pull them in some?
Thanks, this is one of the few bumper options that I like!
I just ordered this bumper.Open box that isgot a good deal 399 shipped
The scuff marks give it personality in my opinion. Badsquatch is coming along.
Thanks to
https://www.extremeterrain.com/ford-bronco-accessories-parts-2021.html?rd=1
I did the one man method and did not pre load the the massive tow plates that together are as heavy as the main bumper almost!. No wonder according to the assembly instructions you need two people.
Sorry took some time to respond. Life gets in the way….had to regain password etcI just ordered this bumper.
Can you tell me about how you attached the tow plates separately - was that before or after the main bumper install? i likely will be doing a solo install myself. Any tricks to this - how you bolted up the two plates etc. Thanks!
Installed and done! Notes:Sorry took some time to respond. Life gets in the way….had to regain password etc
Its quite straightforward like the video, you instal the reinforcement brackets first, pre load the steal plates on the main bumper and man it up until you get one of the nuts on.
Parking a bit up hill as gravity helps keep things place as you get all the fasteners on.
I hope you have an easy time like I did.
