Baja Designs 8x XL Linkable Kit Installed
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Well this kits been sitting at my house for a month or so now. We finally had the truck wrapped and it was time to install the bar (didn't install it knowing I'd have to remove it when we had the truck wrapped, since we had the entire pillar wrapped in a satin white).
Installation wasn't bad at all. Since I had done the 6x Linkable Kit on my bumper, it was basically the same process. I did have to get my wife to help me hold one end up.
The only thing I do not like is the harness off the light bar. The upfitter harness plugs into the light bar and the plug sits about half-way down from the windshield. I know some folks have run the wire under their soft-top but I wasn't about to do that. I do plan to just make a new harness/connector myself but since I was doing this at home, I didn't have all of my weatherpack and wiring that I do at the shop. So that's a project for later on this week.
Wheels/Tires/Lift Kit go on tomorrow, which is why I did this at home (as it's getting dropped off in the morning for the rest). But here are a few shots of the kit installed on our Bronco.
As always everything you see installed on the truck, we carry on our website at www.4x4TruckLEDs.com
Roof: Baja Designs 8x XL Linkable Kit
https://www.4x4truckleds.com/baja-designs-roof-light-bar-kit-for-2021-ford-bronco/
Bumper: Baja Designs 6x XL Linkable Kit
https://www.4x4truckleds.com/baja-designs-xl-linkable-kit-w-6-xl-lights-for-2021-ford-bronco/
A-Pillars: Baja Designs XL80
https://www.4x4truckleds.com/baja-designs-a-pillar-kit-for-2021-ford-bronco/
Fog: Diode Dynamics SS3 Max & SSC2 Pro on the KR Off-Road Brackets
https://www.4x4truckleds.com/2021-f...w-diode-dynamics-lights-kr-off-road-brackets/
Rear (not pictured): Baja Designs S2 Sports Under the Bumper
https://www.4x4truckleds.com/2021-ford-bronco-reverse-kit-w-baja-designs/
Ford Bronco Baja Designs 8x XL Linkable Kit Installed 1636328048670
Ford Bronco Baja Designs 8x XL Linkable Kit Installed 1636328062095
Ford Bronco Baja Designs 8x XL Linkable Kit Installed 1636328075305
Ford Bronco Baja Designs 8x XL Linkable Kit Installed 1636328087900
BTomorama
Atlanta, GA
2015 Nissan Rogue
I wo Der why there is t any Aux wiring connections at the two connection points. Seems like the could have had a center aux connect in between the two bolts.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Where, on the roof itself? There is an aux wire inside the vehicle but you'd need to drill a hole to get it outside the vehicle. That and that wire isn't going to be thick enough to handle 16 amps of power, which is what those XL lights pull
bigblueboing
Keith
Los Angeles.
Forester
I bet you can see your whole life flash before your eyes when those are all lit up!!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I've never actually seen it at night with everything on, just the fogs. I've got the rock guards on (I like how they look) and i've yet to honestly drive at night with the covers off. I'm ASHAMED to admit that actually :(
Once the tires/wheels go on i'll drive take some videos at night with the covers off and lights on
bigblueboing
Keith
Los Angeles.
Forester
It looks very impressive!
Btw ty for the special deal.
Just waiting for the truck to install them on.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
dweskamp
Dan
Missouri
2016 GMC truck
I've bought all my lights from you guys, but that harness running down pillar looks terrible. Has to be a solution for that, if not I'd take them off.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
mom gonna make my own but I’ll have to talk to Baja about their design as I agree I don’t like the harness - you’ll always have a harness down the side with any light bar but the connector there bothers me
FJ 432
Randy
Littleton Colorado
2003 Tundra
I read a piece in Overland Journal about Baja's 6LP Pro. Any thoughts?
dweskamp
Dan
Missouri
2016 GMC truck
Ya that's a big harness, I thought there was access from top to inside, but not for something that big. All my lights are waiting put together for a 12/13 build. Baja bumper pod, Lp6s, diode pros, C1s, and Era4s
dweskamp
Dan
Missouri
2016 GMC truck
I have the Lp6s for the bumper in combo, they have hi, low, back lights and side lighting. I'll have to drill mod bumper to mount. Also will use auxiliary switch not upfitter, it would take 2 or 3 spots on upfitter.
Bschurr
NY
Looks good.
Someone needs to make a cover for the roof mounts once the caps are removed and accessories bolted on too!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Hows the wind noise?
YIKES. I mean.. with a soft top it causes a wind flapping effect against the soft top. Now it was windy this morning as I was driving, so I'm sure that had something to do with it, but it definitely added some noise. It wasn't a howling sound, it was actually the wind causing the soft top to flap around more. And oddly it was coming from the rear more then the front. But I mean that's the price you pay for a killer looking bar up top. I do sell wind diffusers, designed to go on straight light bars, so I may take a queue from that and try and design a bar to help that wind flow better
