Badlands, Sasquatch it?
Rockhound
Oregon
Land Rover Discovery 2
I have a Badlands on order, did not Sasquatch. Starting to wonder, besides the tires, wheels, larger flares what it also includes on this package.
Looking for some crawling, sand, trail capability. Not looking for large obstacle clearance.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Seems like you already have a good idea; no other major differences. The SAS bilsteins give a purported mild lift over badlands bilsteins but there's been research that it comes at cost of articulation
SAS tire contact patch gives arguably better 'float' on sand, but I'd say that's marginal. You're narrower with non-SAS badlands and to me that's stronger point for (narrow) trail capability (esp if you ordered 4dr)
Seems like you made the right choice
Sincerely,
Dude spending too much $ upsizing to 37s right now
Ninjak
Miami
You can always go the aftermarket route. I had the non SAS, but I have upgraded to Fabtech /w Dirt Logic Coilover lift. I am also on 37's. Though honestly I am regulated to FL parks, but its still fun.
The lift is great and the ride is very good. The cooper STT Pro's work very well on the streets as well as with the rough stuff.
BigHoof
PA
Ram 2500
Gears too depending on if an auto or stick.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
The biggest thing it is missing is the axle ratio if you ordered an automatic transmission. Non-Sas is 4.46 ratio, Sas is 4.70.
Everything else is wheels/tires/suspension... everything that can be swapped easily.
To @BigHoof's point... If you ordered the manual... no worries because 4.70 axle ratio is standard.
Rockhound
Oregon
Sincerely,
Good point, thanks. Currently in a 2000 Land Rover Discovery 2, 3in lift on 32’s. It does what I need, just aging and getting harder to find expensive parts. The 265/65 18 tires are not floaty in sand, but I get anywhere I want to go.
FloridaBurgBronco
Don
Middleburg, FL
'24 4Runner TRD, former '22 Bronco Badlands owner
Yes, I did the same thing, saved $4000 and did the Sasquatch myself for less than $1200-1500. I even got the fenders to match a Sasquatch. There's hardly $4000 worth of equipment. Keep in mind, some Badlands will have different option packages that don't make it that sizeable a difference, but mine was a stripped 2 door, no options with a manual, so the difference was huge, $4000. I sit about an 1 1/2" higher than a SASQ up front and a 1/2" at the rear for a level look. I initially did a 1" lift all around, but didn't like it, so finished the front with a 2" lift. Not crazy, but gives it a nice stance. IMHO.
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
My opinion, you're probably fine as is. I ordered just like yours and ran it all over the desert in Utah absolutely fine on the stock BFGs. I only started lifting (mildly, GRT Perch Collar lift) when I got to climbing up and down rocks in the mountains and Moab and the like.
Frankly, choosing my own lift, wheels and tires, once I'd run it a while up and down mountains let me get it just right for me anyway, so I have very few regrets.
01tundra
Middle TN
2003 Toyota Tacoma / 2021 Nissan Titan XD
Do the non-SAS BL's come with auto way bar disconnect?
We're planning on running mild trails in stock form and hope to avoid any warranty arguments, so a SAS package is a good option us. If we had to do it over we'd order the SAS package again.
Sure you can get it close for less money, but our goal was to have the most capable vehicle possible off the production line.
CordellMusic
Keith
ATL, GA
Honda Accord Coupe EXL
Non-Sas Badlands has automatic sway disconnect. I'm on a non-sas Badlands with high package, and I've been out for the last 2 weeks in Colorado, Moab, Montana, Idaho... I haven't run into anything that this thing can't handle other than mud, but that's the price you pay for the smooth on road experience of all-terrain tires on a long road trip. Unless you're doing some kind of extreme rock crawling (and in a brand new Badlands, unless you're totally loaded $$$$, why...?), the difference between sas and non-sas is negligible on a Badlands.
