Badlands Bronco Thread
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Ever car/truck I have owned has given me gearing options From factory. I have 4.10 in my Silverado and LOVE them.
Gamecock
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
@BadBlueBronco
Kc
Los angeles
Ford Bronco Badlands Bronco Thread DFE9E4E5-06B7-4F2E-BE49-9780301B07FC
It’s more common than you would think. Obviously I don’t have any facts from ford but I got my mustang with 4.10 from the factory as well as my Silverado. Hands down the best modification to the vehicle. Blows the doors off identical models with stock gearing. Doubt ford will let you go past 4.7 but I wouldn’t bet against that.
North7
North Texas
SUV
I hope your right, but the Bronco pdf is very clear that this is not the case.
Philly
Dallas, TX
2022 JL Rubicon
If I am able to option for the 4.70 gearing with the auto and 2.7 on the Badlands then I have 0 reason left to get the Sasquatch package. I hope this is the case. Wouldn't even mind if it is only an option with the tow package.
@BadBlueBronco
Kc
Los angeles
Ford Bronco Badlands Bronco Thread 2CD8DD37-9D08-4BD9-B332-6283853058C2
Ok ya I see what you are saying. Wow that would be a dick move.
Dr.Z
Phoenix
Still $6K is a lot of extra $$$ for shocks, grille, and aluminum wheels. The display would appear to be the same.
You're adding FSB disconnect, locking front axle, automatic On-Demand 4x4, and LT285 instead of LT265 tires, and shocks, grille, and aluminum wheels.
Now if you add sas, it all starts to make sense. But without sas, for me, it's hard to see the value for the extra $6K.
Again, just trying to justify the $$$ difference between the Black Diamond and the Badlands. Shocks, tires, and wheels are easy enough to change and probably will be at some point.
The hard bits , FSB disconnect, locking front axle, automatic On-Demand 4x4, and grill, would be hard to source in the aftermarket (if ever). However, are they worth $6K to get? That appears to be the quandary.
The gauge cluster? Is it not the same?
Getting the SAS suspension without the fender flares also. The height / suspension will be different compared to the BD...
SkullsWalk
Charlottesville, VA
2012 VW GTI 3-Door Manual
You will be able to choose your gearing separately.
Just curious where you got that from. As far as all the documentation goes, it only says the manual gets 4.7 gearing or sasquatch (auto). Never heard it was standalone unless you're talking goong aftermarket.
Dr.Z
Phoenix
Where I kind of am is this... What's a better choice? A BD with Sasquatch or a BL without.
Obviously we all know the differences, but what's a better choice if the money is similar and they are optioned similar... :unsure:
BL... same suspension and height... nicer interior and exterior stuff + sway bar disconnect even though it’s not needed often... can keep the manual even = winner
@BadBlueBronco
Kc
Los angeles
I’m basing that assumption on most other vehicles in its class having a few different gearing options. I am hoping that the first release of vague information isn’t all that’s available.
A man can hope
SkullsWalk
Charlottesville, VA
A man can hope
Gotcha yeah I'm with ya. Saw what you posted on how Chevy does it and that would be awesome if we could pick gearing.
Philly
Dallas, TX
2022 JL Rubicon
A man can hope
I know most trucks allow different gearing, but last time I looked at wranglers the gearing was tied to trim packages. So you could only get the 4.10's with the Rubicon package.
I think 3.21 was standard with manual on all other packages, but if you got the tow package with the manual you could get 3.73's. The 3.73 gearing was also standard with the automatic transmission. I think some early years of the JK you could also option 4.10's into the Sahara, but I am not positive... and I guess it doesn't matter unless you are buying used.
Things may have changed.
Edit: 3.45 gearing looks like it is standard on non-Rubicon models regardless of transmission or engine, but you can option 3.73's with the diesel and automatic on the Sahara models. Since when do those only come in 4 doors?
CanadianHorseMan
Rob
Toronto, Canada
2017 Shelby GT350R || 2019 Golf R
From everything I've read it seems as though the gearing is already thought out by Ford and I'd be surprised if you could pick any gearing you wanted during a build. But who knows. I guess if you pay anything is possible.
