Badlands 33" BFG K02 Load Rating?
chartzilla
Morrison, CO
2000 Land Rover Disco 2, '79 Corvette, '17 Elantra
I've been trying to find this info for the past hour but haven't turned up much. Has Ford released detailed info about the tires on Badlands trim? I know they're the 33" BFG K02s, but based on my searching on Tire Rack, it looks like BFG makes both "C" and "E" load rated K02 tires in the LT285/70R17 size. I plan on doing a good bit of offroading here in Colorado, so I'm hoping it's the "E" rated ones as they're generally better at resisting punctures from sharp rocks out on the trail... But I suspect Ford probably went with the "C" rated ones for better ride and $$$ reasons. Anyone know?
Khayze427
Hayes
Valley Forge, PA
Jeep JKU
I don’t know, but your question is a good one. I run “E” rated KO2s on my JKU. If “C”, would switching to “E” rated tires improve the GVWR? Or are the Bronco axles the limiting factor?
