Bad oil pan on 2.7 engine
Mpali
Illinois
2022 Wildtrak
I have heard of 2 people posting that when they took their drain plug out the oil pan was stripped inside. Is that a common problem?
da_jokker
Jeep Wrangler JKUR
Don't think it is very common But then it can there's a lot of people that don't do their own oil changes.
for me, It has convinced me to go to the dealer for the first oil change. The guy that this happened to ended up eating the price of a new oil pan simply because he's the one who touched it first.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Nope.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
I was the other one. After I read the first guys post I let Ford do my first change. I did, however, notice the area around my drain plug had some oil seepage. They inspected and noticed the inside of the pan the tabs didn't exist..i don't think this is common. Mine was 100% covered under warranty and zero issues with it
da_jokker
Jeep Wrangler JKUR
I'm still baffled what's holding the oil plug in on these specific ones? I am not a believer of doing a "break in oil change" on these newer vehicles, it sounds like I may be having it done sooner than later just to rule out a bad oil pan.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
Just have them check inside the plug hole and make sure the little tabs are in there. They are what the plastic plug threads onto. Mine didn't have any. I noticed a spot of oil on the ground so i looked up there and saw the plug was out a little. i twisted it back in and it was sealed. Then i had it again and this time i just tried pushing it in and it went in. Thats where i got nervous. I actually ran a Ziptie around the little tabs to keep it in place and keep it from backing out. This held out fine and didn't move until i brought it in for its first change. I told them that i had issues and they checked it out and found the plug didn't stay in as it should. I also had an o-ring on the filter cap that was pinched(one of the bigger ones) so they dealt with that too. Now it seems good
da_jokker
Jeep Wrangler JKUR
You know that reminds me, I'm going to add check drain plug to my dealer pickup list! Going to make sure it's tight before I even leave the lot.
