Auto Trans Stuck in 1st Gear
JWBroncoATL
Atlanta
Toyota Tundra
This just happened to me. Bronco would not upshift coming out of a stop at a light.
I thought maybe I accidentally was in M. I was not. I was in D.
I shifted to N and back to D. It would not upshift.
I pulled over, put the transmission in P and cut the engine and re-started the engine, put in D and drove off. All a-ok since.
Did you ever figure anything out?
sorry if I’m being dense, but I didn’t understand your story about buying more transmission fluid. Is the Bronco a sealed system and you can’t add more fluid?
0ne
Nate
CO
Flex
Dipstick is on the side of the transmission and only accessible underneath.
BigBetty
Fai
Atlanta GA USA
This morning I pulled my Bronco out of the driveway. I headed down the street and cruised up to the stop sign within in 200 feet from my house. Hung a left and the transmission would not shift from first to second. I had the auto stop/start disengaged. Drove about 100 yards more to another stop sign and still no shift. Pulled away from the stop sign was about to hang a u-turn and the trans shifted to second. drove it for a while and everything appeared to be normal and it has been running normal ever since. Has anyone else had this happen? It is a Badlands four door with the 2.7L
Hi I believe this is what happened to me this past weekend. I reported it to the National Safety board.
Bronco_007
FL
Two ponies in the barn: 1974 U15 and 2024 U725.
This has happened to me twice. Once today and again about two months back. Both coming out of a red light after driving for about an hour. Had to put in M and back into D to get it to shift. Also has Auto Engine Shut Off disengaged. Anyone take it in to Ford? What was transmission fluid level at? 24 2.7 WT 4D
